Codes 21 and 24 are probably because you did not let the engine warm up enough. Code 25 is being caused by not doing the goose test, just like code 77 is. 41 is your old O2 code that is still there, you need to make sure the engine is fully warmed up for that also. Did you figure out that mystery wire?
Yes, just did it. 21 and 24 went away. I'll have to retest tomorrow and do the goose. I miss read the book. 10 means rev, I thought it meant done. Neighbors are having a dinner party on the patio and wife says, I have to put my toys away and play nice. They weren't happy with my idea of ambient back sounds of an old truck being worked on. It is running better and no surges. The rich smell is gone also. The wire to the old O2 was soldered to the exhaust manifold.
Reason: more info
I would pull that harness apart and see where that wire goes and see if you can find were it went. That is the computer harness, it's not good having loose wires in there.
You have a link to Gary's site with the 86 diagrams correct? Print that off, pull those wires out of the looms and have some quiet time to figure out what is going on.
Okay. Done all things suggested. I even cleared out all codes and started fresh. * new O2, EGR, and EVP.... test R 44, 34 codes. Test O and C both 11 codes. I fell like I'm 2/3s the way there.
Reason: correction
Code 34
sometimes the shaft on the EVP is to long.
measure the output.
shim the EVP as mall amout, re-measure, run self test, repeat if no improvement.
