Turbo'd i6
Old Apr 13, 2018 | 04:34 AM
Zachary Cartwright's Avatar
Zachary Cartwright
Turbo'd i6
I have an 300 i6 EFI that I am planning on putting a turbo on to get some oomph out of it... Will my ecu function with 10-15psi blowing through my throttle body or will it lean out? I've got an almost identical post to this in the fuel systems thread... Thanks in advance for any and all answers.
Old Apr 13, 2018 | 08:54 AM
Franklin2's Avatar
Franklin2
It has to be programmed for the positive pressure. You may also need a special MAP sensor, not sure about that. I do know the EECIV can manage a boosted engine, I used to have a 85.5 Mustang SVO with the turbo 4 cyl. But the Ford EECIV is not very friendly to modify, there are companies that sell stuff to do it, but I think I I were you I would go with a aftermarket EFI system that is more generic and easier to program.
Old Apr 13, 2018 | 08:57 AM
Franklin2's Avatar
Franklin2
P.S. The more I think about it, the more I realize how I am probably too uniformed to answer your question. The 5.0 mustang guys run superchargers and stuff all the time. I would copy what they do to get their cars running, it's the same system, just two less cylinders. If you do not have a MAF in your system now, you may have to add one. See what the Mustang guys are doing for their cars.
Old Apr 14, 2018 | 03:27 AM
Zachary Cartwright
Alright... I'll look for an efi dilly on the internet... They should have then fairly cheap... I hope
jem44357
Jan 13, 2010 09:36 AM
79 f-150 guy
37
Apr 18, 2009 10:58 PM
navyflyinggreg
Nov 11, 2004 10:49 PM
77fromheaven
Nov 7, 2002 05:48 PM
kameleon
Feb 15, 2002 08:08 PM
