Issues starting
Old Apr 12, 2018 | 08:28 PM
Hick1997's Avatar
Hick1997
Issues starting
Im havin issues on my truck it aint startin like it should so i thought it might be the solenoid again so i changed it an nothing then did some research an ended up changin the clutch position sensor an still dont have anything i can cross the solenoid an it will start no issue but i cant do that 247 an i was wonderin what yals ideas are an this is a 1990 ford f250 xlt lariat 4x4 with the 5.8l an a standard 4 speed trans with overdrive an ive been drivin this since last year when it had 184000 miles an it turned over 200000 this past week
Old Apr 12, 2018 | 08:35 PM
sandymane's Avatar
sandymane
Please describe your starting issues. What does it do when you try to start it normally and exactly what happens. More info will get you going. In the meantime you might want to figure out how to get the pigeons out of your barn/shed. Welcome. Sandy
Old Apr 12, 2018 | 09:54 PM
Hick1997's Avatar
Hick1997
That was the pics of thr the truck when i got it an when i try to start it it would take a couple hits of thr key for it to start then it would start every now am again il have a runaway starter because the solenoid sticks an lately it was just not hittin like it should id have to pump the clutxh an put it completly to the floor
Old Apr 13, 2018 | 12:48 AM
Chadeterry84's Avatar
Chadeterry84
I can get my 89 F250 started but if I let off the gas it dies do you know anything that could be so I can fix it
Old Apr 13, 2018 | 04:54 AM
Hick1997's Avatar
Hick1997
Sounds to me like you aint gettin enough fuel
Old Apr 13, 2018 | 06:25 AM
vjsimone's Avatar
vjsimone
When was your last tune-up?
Try removing and cleaning your Air Bypass Valve, use a new gasket to re-install.
Old Apr 13, 2018 | 07:50 AM
rla2005's Avatar
rla2005
Best advice is to start your own thread. Jumping into another person's thread for a different issue is considered poor web etiquette.There is a New Thread button on the upper left of the main forum page.
Old Apr 13, 2018 | 08:22 AM
subford's Avatar
subford
A sticking solenoid sound like trying to start the engine with a low battery. When the battery has low voltage the current from it will be much higher and can weld the contact plate to the contact points in the solenoid.
F250 Big Hank
Aug 1, 2019 05:04 PM
paddler
Dec 18, 2010 06:41 PM
thedettras
Electrical Systems/Wiring
Oct 31, 2004 07:54 PM
1994ford
Dec 12, 2003 09:04 AM
kev100
Apr 15, 2003 03:05 PM
