Heater cables / knobs
Old Apr 11, 2018 | 07:48 PM
GoldCo's Avatar
GoldCo
Heater cables / *****
What was original layout for 52 Magic Air, L–>R?
I’ve got original cables, but don’t see which cable goes where for the 2 ***** on the right (left is motor switch, next is fresh air).
Can’t tell from wrapped cable ends either, as both actually seem like the should have 90* bend for proper orientation to housing stop. ??
Old Apr 11, 2018 | 08:04 PM
firstrider's Avatar
firstrider
Blower - -Air - Defrost - Temp . . Have a restored cable control panel w/ the correct decal on it if you are interested .Denny a.k.a. MAHK Magic Air Heater King on FTE .
You can also put new ***** on it by grinding the shaft down a little , hold it w/ cloth rag under vise grips & run a 10/32 die for threads . Also have many of them here .
Also have extra cables her if needed..
Old Apr 11, 2018 | 08:23 PM
GoldCo's Avatar
GoldCo
Thanks…
So do I just push the cable on and then put a 90* kink in it?
Confused why they wouldn’t already be bent??
Old Apr 11, 2018 | 08:57 PM
firstrider's Avatar
firstrider
Insert some thing in the cable end the sane dia. as the door lever & put a 90 in it . The bottom pic bend it down . Some one bent them straight.
firstrider
41
May 20, 2023 12:42 PM
Twistedwrench
Sep 16, 2012 08:12 PM
montego69
25
Dec 13, 2010 06:51 PM
tip49
Jul 28, 2010 12:09 AM
