e-brake cable boots
Old Apr 18, 2015 | 07:58 PM
firstrider's Avatar
firstrider
e-brake cable boots
I know many times I've said that soon they will be made so while I'm in a molding state of mind have made some progress on the mold . Made a silicone rubber inside buck of the e-brake cable boot . Next step is to have a buddy machine an aluminum replica of it . Will have him make 2 .Then remount the boot on the buck . Lay it 1/2 way + in a small tub of material to create 1/2 of the outside mold , repeat & sand the flat surface till they match . Remove original e-brake cable boot from inside buck ,drill some 1/4 -20 holes thru the matching halves , bolt together , stand in a jig , pour in liquid rubber & wait 8 hrs. , remove & hope what I have is an exact replica of an e-brake cable boot . Remember each truck needs 2 .Also spoke to Chuck @ Chucks trucks . He is sending some big truck shift lever boots to reproduce . Those should be a little easier as one end is bigger than the other. These e-brake cable boots are a challenge as both ends are smaller than the middle . Stay tuned .
Old Apr 19, 2015 | 11:23 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Very Cool!
Old Apr 19, 2015 | 03:52 PM
underthebridgejim's Avatar
underthebridgejim
FTE fan
Thumbs up
That is so cool. The talent that so many of you possess just amazes me.
Old Apr 19, 2015 | 06:10 PM
firstrider's Avatar
firstrider
Am going to make an attempt at reproducing the blower motor switch for the '48-'50 FORD script fresh air heater . Have some old ones that I can take the inside metal fixture out of & cast it right into the switch ****. As long as I am on a roll with parts making will get some clear liquid plastic and make an attempt at reproducing the clear plastic cable control panel for the '51 Magic Air heater that is back lit & says Blower Air Defrost Temp No one makes these either . May slow down in woodworking , cabinet , furniture repair & restoration & concentrate on making parts as uncle sam contributes to the monthly paycheck now.
Old Apr 24, 2015 | 08:03 PM
firstrider's Avatar
firstrider
I now know what the inside of an e-brake cable boot looks like & the diameters of the bellows shape . Now to have a couple machined out of aluminum .remount the boot & make the matching outside molds .
Old Aug 19, 2015 | 12:36 PM
firstrider's Avatar
firstrider
Progress ,now to find the time to set up the outside mold halves ,A jig to hold them ,pour the rubber & hope for a good result .
Old Aug 19, 2015 | 06:29 PM
jonf's Avatar
jonf
while you're at it, how about making the rubber belows that the gas pedal linkage goes through. they are available already but $25 is too much for a tight wad like me.
Old Aug 19, 2015 | 06:38 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
DC has them for $9.95.
Accelerator Pedal Rod Seal | Dennis Carpenter Ford Restoration Parts
That's for different years, but looks like it would work.
Old Aug 19, 2015 | 07:59 PM
firstrider's Avatar
firstrider
No thanks , finding time to make obsolete parts is hard enough . Am only interested in making parts that are not out there .These will be $30.00 / pair . Small price to pay to keep your e-brake equalizer clevis ends weather tight . Already have $$ & hrs. in the venture and not one boot made .Stay tuned .
Old Feb 5, 2016 | 07:36 PM
firstrider's Avatar
firstrider
UPDATE !!!! Made sometime to find a compatible container , modify said container , measure displacement amount , mix silicone for outside mold , pour in & etc. Sat . will see how it came out . E-brake cable boots soon !!!!
Old Feb 5, 2016 | 07:55 PM
3twinridges's Avatar
3twinridges
Can't wait Denny. It's great you are making the pieces not available. The heater boot is special and works great for me! Thanks
JB
Old Jun 13, 2019 | 10:33 AM
firstrider's Avatar
firstrider
Was under "Art' " sat .removing the hard lines on the trans so I can replace with steel braided lines & decided to also remove the truck
e-brake cable boots which are different than car e-brake cable boots . Made a little head way on the reproduction progress . Managed to slip the OEM boot on the inside buck .It was a battle as the old boot went on tight w/ the help of silicone & soap . Will have the original part # on them . OIY -2597 .
Old Jun 13, 2019 | 05:20 PM
Moe Craig's Avatar
Moe Craig
Boy they look like you getting them down now. I need to let a friend know and will need to get me a pair soon too as I'm looking for parts to make my E-Brake complete. I'm missing the bracket that is on the tranny crossmember
Old Jun 19, 2019 | 02:40 PM
KirkF's Avatar
KirkF
Those look great!
I'm patiently waiting for a set to finish off my e-brake!
when do you think you will have the first sets ready to go?
Kirk
Old Jun 19, 2019 | 09:17 PM
firstrider's Avatar
firstrider
Well now that I have a truck to repair maybe awhile . Some incompetent rad rod builder started his rig & it took off & ran into the First Ride at a show on Fathers Day . The thread has been closed . It started to get out of hand so the moderator shut it down .Thank you to him .
