1960 wiring help!!
I don't know of a way to replace the wires into the actual bulkhead connectors. Best bet would be to splice in new wires & try to cover up with heat shrink best you can. I completely re-wired my 60, but I used one of the Painless Wiring universal harnesses. My only complaint is that there is no option for a bulkhead connector - all wiring has to run out a hole in the firewall. From your pics, it doesn't look like the wiring is butchered beyond repair. Unless you're worried about a "Professional" look, I'd go through & clean up loose wires & sketchy splices, then wrap with some kind of loom. I got an assortment of stuff called powerbraid from summit that works pretty well.
Coastal68
28
11-14-2015 07:02 PM
F100Jay
04-06-2015 02:51 AM
55fordtruck
Electrical Systems/Wiring
04-26-2004 09:59 PM
