timing chain guide issue
Old Apr 11, 2018 | 10:44 AM
RickyD's Avatar
RickyD
I have installed a new timing set on this 5.4 and it seems to me that the right side guide is excessively deflecting the chain. if ran this way it will surely wear into the guide. This isn't normal is it? I just looked at the old guide and it does show wear and seems dimensionally the same (ebay kit) Anybody have thoughts or even noticed or am I being paranoid ?
Old Apr 11, 2018 | 04:25 PM
F150Torqued's Avatar
F150Torqued
It's hard to tell in the photo. It does seem to me also that there is more angle placed on the chain at that point than I would expect. I seem to remember the guides (L & R) are different part numbers - because I got a set with two the same and had to exchange one. You sure they are right / and right side.
I'm attaching the best picture I've ever seen of an opened up 5.4L front end (not my motor, but a photo from a member I helped count 'chain links' to help verify correct timing on his). Don't think he will mind.
Old Apr 12, 2018 | 09:03 AM
alloro's Avatar
alloro
It looks like the left inner guide is installed at the right outer location.
Old Dec 24, 2022 | 12:14 PM
Nuttbuster's Avatar
Nuttbuster
Trailering
My 1999 Ranger 3.0L (production date: 4/99) was purchased from the original owner with stock ratio aluminum roller rockers... About 1/3 of them have flatten out tips to valve surfaces and they are noisey when floating the rpms/no load 3,000+ If you drive it normally you never hear them.
So I want to replace the worn out ones or just install some stock rockers also going to replace all the roller lifters too because of the thrust plate issues.
Problem is which rockers to run... It's a 4/99 production date so I've heard that 07/99+ are different and are compactable with newer Rangers?
Will ones from a Taurus or Aerostar work?
Thanks!
gabriell12123
Sep 21, 2018 05:22 PM
SSStang
Oct 13, 2017 07:08 PM
Eric1976mi
Aug 3, 2017 07:57 AM
Redworks
Jul 16, 2015 03:55 PM
fishindave11
Nov 16, 2008 02:27 PM
