Measurements for leveling
Old Apr 10, 2018 | 09:45 PM
fmuguira's Avatar
fmuguira
Heres my question; see lots of folks quoting how much rake their truck has in inches and then trying to determine what amount of front leveling to run .... where is everyone measuring for their determination? I m guessing the bulk of the measurements are from the floor to the bottom of each wheelwheel/fender and then comparing front vs back but just curious? Doing such a measurement assumes Ford built these trucks with the exact same wheelwell radius front and rear.
Looking forward to input.
Thx
Old Apr 10, 2018 | 11:30 PM
pezracer's Avatar
pezracer
Your thinking is right, measure from the ground to the bottom of about the center of the fender. No need to over complicate the measuring, 2.5" seems to level them real nice, but you might opt for 2" if you still want a tiny bit of rake.
Old Apr 11, 2018 | 12:05 AM
18CCLBKR's Avatar
18CCLBKR
Yup ground to wheel well. That's how ford does it on the lean TSB.
Old Apr 11, 2018 | 08:37 AM
fmuguira's Avatar
fmuguira
Thanks for confirming TSB method; that makes the most sense then!
Old Apr 11, 2018 | 09:09 AM
18CCLBKR's Avatar
18CCLBKR
Correction: measure from wheel lip to wheel well opening.
File Type: pdf
steelhead2
Feb 15, 2012 11:11 AM
efizzle
Mar 1, 2010 04:36 PM
little big red
2004 - 2008 F150
Jan 6, 2008 02:42 PM
salesman112
Jan 5, 2008 10:03 PM
flareside_thunder
Dec 2, 2007 05:38 PM
