Zf-5 gas vs diesel bolt patterns
Old Apr 9, 2018 | 10:30 PM
78Broncoinpieces's Avatar
78Broncoinpieces
plan is to put a ZF-5 in my 78 Bronco, 460 engine with NP203, currently 3.50:1 gears.
truck will be 95% street use so the 1st gear of the wide ratio/gas version, 5.72:1, will be way too low.
I'm thinking the close ratio diesel would be a better fit, only 4.14:1 first gear on that one.
I've been told the bell housing pattern is different, some but not all of the bolts will line up.
can the diesel bell be easily modified to fit a 460? locator dowels OK? any starter fitment issues?
Thanks
Old Apr 10, 2018 | 05:06 PM
85e150's Avatar
85e150
Everything I find says two bolt holes need to be redrilled, and a pin relocated. No comments about starter.
It's been done.
Old Apr 14, 2026 | 07:25 PM
freddy’s f150's Avatar
freddy’s f150
1st Gear
Thanks
Did this swap end up working for you? I am sitting in the same boat right now of trying to figure out if it’s even worth it or to just stick with my c6
Old Apr 15, 2026 | 03:24 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
It's by far best to try and find a Ford bellhousing pattern than try and use Internationals of course. These trans shouldn't be that hard to find.
As for if it's worth swapping to an OD trans at all (Ford to International pattern aside) that really depends on how often you use your truck and what speeds you drive at.
If you only put on 10k miles or less per year and drive mostly 45mph on back country roads, it's not going to be as worth it (perhaps not at all) of course compared to if you drive 20k miles per year and run 75mph interstate speeds most of the time.
If you're right in the middle, putting on 15k per year, driving average speeds of 55 to 60, I'd say it's worth it, so long as you plan to keep the truck a few years.
If you're driving a lot of those miles empty, not doing truck things, then no. Wont be worth it. Keep truck as is and drive a small 4 cyl car when you don't need the truck to get 30mpg+ and blow the small OD benefit out of the water (save thousands vs hundreds. Big oil will hate you, but your wallet with love you.)
80ford100
Jun 29, 2015 10:29 AM
EJDobbins01
Aug 25, 2012 02:57 PM
kona56
Aug 8, 2010 10:39 PM
rickgthf
19
May 16, 2006 11:18 AM
runawayford
Feb 29, 2004 09:03 PM
