I have a 97 f350 7.3, dome light and odometer quit at the same time, truck is shifting hard and I have to feather the accelerator to get it to shift. Was told possibly the solenoid pack in the transmission, or the brain box. Thanks in advance.
We will try to get this moved to the OBS section so that you can receive more informed/relevant assistance. Welcome to FTE. You found the best forum on the net.
You say the odometer quit, meaning there are no digits displayed, or the mileage numbers do not increase? If no digits are displayed, check fuse #18 in the in cabin fuse panel.
yes, the odometer quit, no mileage showing and the speedometer quit as well. I checked all the fuses when it first happened, none of them were bad.
