Hi guys..n ladies:
I have an odd issue. I lost power to my visor mirror lights, home sense garage door opener and one function of my map light. At the same time my tire sensors went out one by one. Does anyone know where i can find schematics or wiring diagram to trace out cct? Or have experienced this problem. I have a 2010 f250 superduty lariat fx4 offroad. 6.4L Diesel.
Try ALLDATAdiy.com Join for around $15 and has all the repair info you could use. Did you try checking the electrical plug down by the parking brake? They have been known to become loose.
There is a plug by the parking brake? I will check that out tonight. Thankyou. Are you thinking like the ground is loose? Or does it affect multiple areas?
The plug itself comes loose, causing all kinds of electrical issues. Something to check before you tear your hair out tracing circuits.
I have seen in one of my trucks where certain functions stop working, then all the dash warning lights come on, then flash, guages stop working , then start again.
If the plugs down there check out ok, then start looking for a bad ground.
