ground straps
Old Apr 5, 2018 | 07:45 PM
CB3's Avatar
CB3
ground straps
I have a 1978 F100, 302. The motor has been replaced. Where should I have ground straps?
Thanks,
CB3
Old Apr 5, 2018 | 08:08 PM
Blue and White's Avatar
Blue and White
Thanks,
CB3
What I have and would suggest (though may not be 100% original) is at least 3. 1) Heavy ground wire from battery negative to engine block. This one handles starting and engine component ground when running 2) Moderate (eg. 10 gauge) ground wire from battery negative to body. I used the radiator support. This one helps make sure lights are well grounded. 3) Added ground from engine to frame in front. The frame rails have some pre-made holes that can be cleaned up and tapped for 5/16" or 3/8" bolt near the main engine ground. I added this one when I added electric trailer brakes to make sure there was good ground to the frame where the brakes are grounded in the rear.
newguy399
May 2, 2016 12:05 PM
78fordguy
May 7, 2014 06:10 PM
Rick_Fury
Apr 13, 2013 08:01 AM
bikeymikey
13
Mar 24, 2013 09:00 PM
jesse_h97
Jun 13, 2010 12:11 PM
By Verdad Gallardo | 2026-06-03 11:38:19
