Recommendations please
Old Apr 5, 2018 | 07:42 PM
dert's Avatar
dert
Hello all. So this truck is not in great condition for starters. I plan on using it as a work truck and fixing it up over time. It is a 78 f100 classic with the 300. I started by replacing a blown head gasket, found a couple bent pushrods and very worn rocker arm. I replaced them all and carried on. When doing the head gasket I just involved the intake/exhaust from the head and pushed off to the side. Due to poor planning I ended up trying to clean the gasket off the intake manifold after the head was back on. Did not have enough room so I decided to pull the 3 bolts and just take the intake mani all the way off. The bottom of the manifold had very bad pitting and basically just fell off. I have another intake manifold ordered. Since I keep running into stuff and don't want to have to dig back into it anytime soon is there anything anyone would recommend me replacing while I have everything apart? Or anything common that I should check? Also this engine has 480k miles on it and ran well before the head gasket. I am only a couple hundred deep on repairs and don't want to dump money into a well aged engine just get it running good until I am in a place where I can really do this thing right. Mayne in a couple years. Thanks!
Old Apr 5, 2018 | 09:07 PM
VitaminC's Avatar
VitaminC
Pull the motor and rebuild it.
Bent pushrods are no bueno and could be signs of larger issues.
Old Apr 6, 2018 | 06:32 AM
njdevil77's Avatar
njdevil77
480,000 miles on it, Time for a rebuild, you will fix all the issues you are having, tighten everything up and the rest will slowly begin to fall apart.
Old Apr 6, 2018 | 08:35 AM
speedfreak78's Avatar
speedfreak78
If the cylinder bores looked good and it has good compression, run it. With the miles on it, if it hasn't been rebuilt a some point, the bearings might be pretty beat, or they could be fine, without pulling main/ rod caps there's no way to know. Bent push rods could be a sign the motor had been worked hard and over revved. Have you looked at local classifieds, they made these motors into the 90s? Might be able to find a lower mileage motor for a couple hundred bucks.
JayFan
Modular V8 (4.6L, 5.4L)
Mar 31, 2014 09:18 PM
KyleTexas
16
Feb 9, 2012 11:37 AM
Prowood
3.8 & 4.2L V6
Oct 8, 2007 02:41 PM
Series900
Jun 6, 2001 03:12 AM
