Sponsored by: Real Truck
02 sensor problem?
Old Apr 4, 2018 | 01:26 PM
68firebirdman's Avatar
68firebirdman
02 sensor problem?
So I have a 2003 f250 with the 5.4 and this past few months have been battling mileage issues, I recently replaced the o2 sensors asI found that the old ones had 1 reading 0.000 volts and the other was reading outside the spec.
now with the new sensors I still have 1 reading 0.000 volts according to the manuals i dont see any fuses for the o2 sensors on this truck is this correct?
Old Apr 4, 2018 | 01:42 PM
projectSHO89's Avatar
projectSHO89
If your truck is an OBD1 calibration, it doesn't have downstream sensors so you get a reading of zero.
Old Apr 4, 2018 | 01:47 PM
68firebirdman
It is an obd 1 clibration
I was assuming and maybe incorrectly that since That was the only other o2 sensor reading it was reading the other upstream sensor and mislabeling it as a downstream.
Old Apr 4, 2018 | 03:04 PM
projectSHO89
Well, you now know you don't have an O2 sensor problem.
Old Apr 4, 2018 | 03:26 PM
68firebirdman
So am I correct in assuming that there is no reading the other 02 sensor then?
Old Apr 4, 2018 | 07:07 PM
projectSHO89
There are no bank 2 downstreamsensors to be read.
If you need more specific answers, you'll need to ask more explicit questions about specific details.
Old Apr 4, 2018 | 07:54 PM
68firebirdman
Thats interesting I am pretty sure a V-8 motor has both banks and I have 2 upstream Oxygen sensors. So if the 2 O2 sensor isnt bank 2 what is it? every-time I have ever dealt with oxygen sensor the bank referenced the side of the V motor and then the number after that inicated the position in the exhaust system.
Old Apr 4, 2018 | 08:31 PM
projectSHO89
Oops, I should have said "there are no downstream O2 sensors", not "bank 2 sensors". I'll edit the above.
Rumble phish
2004 - 2008 F150
17
Dec 20, 2018 09:09 AM
teamlx88
Feb 14, 2013 06:06 PM
nastruk95
General Automotive Discussion
Apr 27, 2004 07:32 PM
Dayne
1983 - 2012 Ranger & B-Series
Apr 8, 2004 11:27 PM
Crazyromi
1978 - 1996 Big Bronco
Oct 2, 2003 06:44 AM
