steering column rebuild
Old Apr 6, 2018 | 01:56 PM
tobyflh's Avatar
tobyflh
Thanks for the help. My shifter arm is completely loose and the shifter at the bottom was froze, so I thought that I needed a new column tube. Maybe I just need the shifter part (part #7228 on diagram). I'll find out when I get it apart.
Old Apr 6, 2018 | 04:16 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D5TZ-7228-A (replaced C5TZ-7228-A & B; C9TZ-7228-A) .. A/T Shift Collar Kit-Includes D3TZ-7A110-A Plastic Shift Dial Pointer / Obsolete
1965/77 F100/350; 1973/77 Bronco & Econoline.
Note: 1965/72 F100/350 shift collar had the pointer made as part of it. 1973/77 shift collar has a slot in it that the plastic pointer fits into.
The shift collar is pot metal, has an internal bridge that connects it to the shift tube. Over time, the bridge begins to crack, eventually breaks off.
Now you aren't going anywhere because...when the bridge breaks, the shift lever flops around.
Old Apr 6, 2018 | 05:35 PM
deich's Avatar
deich
That part is a usual suspect...
Old Apr 8, 2018 | 08:24 PM
tobyflh's Avatar
tobyflh
the inner shift tube had the little tab came undone and the 7228 part was broke. welded the tab on and have to order the new part. having problems adding a picture.
f100today
25
Jul 26, 2023 07:24 AM
deich
Nov 18, 2017 01:07 PM
Mike in Ohio
Nov 30, 2012 04:25 PM
mrgoodwood
Sep 17, 2012 08:25 PM
Sixoh
Feb 1, 2005 10:27 PM
