Modular V10 (6.8l)
Tranny options
Old Apr 4, 2018 | 10:34 AM
78sForever's Avatar
78sForever
Tranny options
So the trans gave out in my 04. Has anyone had experience with monster transmission or have any suggestions? I do feel like a bts or john wood is overkill for our v10 trucks. Any suggestions appreciated .
Old Apr 6, 2018 | 06:47 PM
78sForever's Avatar
78sForever
Wow, no opinions at all?
Old Apr 6, 2018 | 08:22 PM
Im50fast's Avatar
Im50fast
I’ve been on this forum for years and I’ve never seen anyone talk about aftermarket transmissions.
The stock ones are great. That’s probably why you haven’t had a reply.
Old Apr 6, 2018 | 09:38 PM
78sForever's Avatar
78sForever
I agree, but I still need a replacement just trying to find out what the best ones are.
Old Apr 7, 2018 | 05:53 AM
Im50fast's Avatar
Im50fast
I think I understand where you’re coming from. When something needs replacement on my van I always seek an upgraded part.
Transmission...? Nah. The ford originals are excellent.
Which one one do you have? The 5r110? Nothing better than that. It’s rated for 550lbft of Torque. Good to go.
Occasional failures: sure.
Mine has 334,000 miles on it and I beat the daylights out of it on a regular basis.
I had a sensor go bad causing it to not use the top two gears intermittently , and later on it developed a hard shift into Reverse and Drive. Likely a bad solenoid. Two electrical problems - can’t much blame the transmission for that.
I use my gas pedal (v10 van) like a teenager on a regular basis.
Old Apr 7, 2018 | 09:38 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
A 2004 V10 will be a 4R100 transmission.
I've talked at length with Bob Riley at Diesesite. He knows how to build a good trans, and he dyno tests his before releasing them.
Actually, the rating is after the torque converter multiplication and is rated at 1100, hence the 110 in 5R110W.
Old Apr 8, 2018 | 10:58 AM
78sForever's Avatar
78sForever
Thanks for the input guys, and marks right of course, its the 4r100
Old Apr 8, 2018 | 11:01 AM
78sForever's Avatar
78sForever
Does Bob build them for v10s?
Old Apr 8, 2018 | 05:40 PM
Mark Kovalsky
I really don't know. The only differences would be the case and the torque converter.
Old Apr 9, 2018 | 08:06 PM
78sForever's Avatar
78sForever
Has no one else really run into replacing a 4r100 behind a v10?
Old Apr 9, 2018 | 08:09 PM
78sForever's Avatar
78sForever
And I'm50, I hesitate about a ford reman because I've heard horror stories about being put back together with used parts. Sometimes people specialize for a reason.
Old Apr 9, 2018 | 08:30 PM
Mark Kovalsky
Do you think the specialists replace EVERYTHING in the transmission? Or do they reuse the used parts?
Old Apr 9, 2018 | 08:34 PM
78sForever's Avatar
78sForever
That's a fair point, I guess a person always takes their chances with whatever they choose, so the ford reman is the consensus here?
Old Apr 10, 2018 | 06:21 AM
Im50fast's Avatar
Im50fast
the FTE crowd would ask you that question lol
Old Apr 10, 2018 | 07:33 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
They have, but it hasn't been talked about much here. Usually, people find a good local transmission place and just get it done there. Local place, warranty, no biggee.
Thing is, the really BUILT trannies are for the diesel guys who put loads of ft/lbs through them. The V10, not so much
