Battery life in the 6.7 ?
#31
The easiest thing to do regardless of what you drive, or what battery is installed, is to periodically measure the charging voltage and the battery state of charge at the battery posts. This pays dividends.
If the alternator isn't doing its job, or the vehicles grounds & cables are loose or corroded... There will be problems guaranteed. Even the most heavy duty, expensive battery will fail & fail prematurely. Get all the performance and longetivity you paid for with your dollars.
#32
Batteries are a funny thing, sometimes they last and last and other times they fail quickly. I follow a couple of Ford diesel techs on Youtube and they replace the factory batteries fairly often, especially for leaking.
I would expect a pretty lengthy service life from the factory batteries considering you have two, and possibly two alternators to charge them. But who knows. I would also recommend the Odyssey batteries if you are willing to shell out the extra dough. Best battery I've ever owned.
FUN UNRELATED FACT: My 2002 Kubota L4310 tractor still has the *original* Kubota 600CCA battery...starts fine, even in near 0-degree weather for plowing in the winter. I'm amazed.
#34
#38
#39
Not the first time it's happened...I grew up not far from the Lafitte/Barataria area and use to fish in that area often. Moved about 10 yrs ago a little further away. Time to roll..taking the wife to Houma. Catch ya'll later!
#40
#41
Over the years we've tried all the restaurants down that way. Des Famillies..Boutte's..Voleo's but like Jan's the best. We live in Lafourche Parish now in the Mathews area. I grew up on the westbank and still have property in Gretna. Lived in Belle Chasse for 32 yrs.
#42
When I took Basic Training in the Army there were two identical twin brothers named Pellegrin in our company, from Houma, LA (which they would always remind everybody) is south of New Orleans. It was hilarious at first because not everybody got the word, so they would get yelled at a lot. "Didn't I just tell you to go report to KP??!!" "That was my brother Drill Sergeant!"
"Yeah right Private!!" Rinse lather repeat.
Ok so ya had to be there.
#43
Batteries replaced about 3.5 yrs
Have you replaced the batteries in your 6.7 yet?
Did you wait until the old ones died?
Reason I ask is that my truck & batteries were 3.5 years old and I got uncomfortable about getting stranded with dead batteries.
(I happened to get stranded in my Jeep with it's factory battery - approximately 4 years old on Easter day. I didn't like that a bit.)
So I replaced both batteries in my 2015 Super Duty (took delivery in Aug 2014).
Just wondering what the factory battery life expectancy might be?
#44
battery replacement
I hope I don't jinx myself but my 2012 SD has the original batteries. I keep them clean and corrosion free. I have been thinking about replacing them with Sam's Duracell AGM batteries. I can get the Motorcraft batteries for the same price but I believe the AGMs are a little better.
I talked to a driver at east Penn delivering to Sams and asked him if the different names on these batteries are as good as DEKA and his reply was all EAST Penn batteries are made with the same quality regardless of name.
Yes the AGM are better cost more as most things of quality do, will take more abuse than wet cell technology.
My 2011 F-350 6.7 PS has the OEM batteries still...
Tip: I recommend putting those treated felt washers over each battery post when doing a replacement of batteries. They can be purchased at WalMart for .99 cents for a pair. Use Arm & Hammer Baking Soda mixed with warm water to clean the corrosion off cables and battery posts.
This solution does a good job of cleaning all acid off top of batteries.
#45
