Washing machine problem
Old Sep 17, 2003 | 04:37 PM
Shepard's Avatar
Shepard
Any appliance experts here at FTE? I'll bet there are!
Anyway - Our 1-1/2 year old Sears Kenmore washing machine (just out of warranty) has started making a loud noise when slowing down after the spin cycle. As the spin cuts off and the tub slows down, there is a loud sound. It is definitly tied to the rpm's of the drum because as it slows down the sound slows also.
I would describe it further as a loud, sort of vibration / rumbling noise. It is almost as if there is too much play in something?
Any ideas?
Old Sep 17, 2003 | 04:53 PM
2Bowers's Avatar
2Bowers
Direct drive or belt drive?
Kenmore should have a direct drive, could be something wrong with the washer transmission. Or else something is hitting the drum, or the drum is out of balance.
Just some ideas. I just install them for Sears, try not to fix 'em unless it's my own.
Old Sep 17, 2003 | 04:56 PM
theologian's Avatar
theologian
Dependent upon the chassis of the machine, there are two things I can think of. In one, the drum is mounted on an aluminum casting with a bearing. This bearing is not too well built and gives - I have met a couple like that.
The other thing I can think of is in another chassis, the whole thing is suspended on a bearing, but also has a braking system, to slow it all down quickly - this also can go south, giving much the same kind of symptom you describe.
I must state that I am not an appliance engineer, just a poor guy who has fixed more washing machines than he cares to remember.
Theo
Old Sep 17, 2003 | 05:07 PM
tellico racing's Avatar
tellico racing
My expertise lies in commercial laundry equipment, however it does sound like you could have a bearing problem. before condeming it though, I would check to see that it is sitting level. When they are crooked the basket tends to bang around inside the drum.
Some models made by maytag (which yours could be) have 3 springs going from the floor of the machine up to the drum to stabilize it, If one breaks it can make the basket scrape the drum
Old Sep 18, 2003 | 01:31 AM
Shepard's Avatar
Shepard
The sound seems to be coming from underneath the agitator in the lower center of the drum. It sounds also like it could be the agitator itself vibrating????
Old Sep 18, 2003 | 05:59 AM
tellico racing
How about a bad belt? If there is a piece of the belt missing it will make noise.
Old Sep 18, 2003 | 08:59 AM
rikfish's Avatar
rikfish
I had a similar noise, turned out to be the automatic fabric softener dispenser mounted on top of the agitator. Try removing it and see if that quiets things down.
Old Sep 18, 2003 | 07:19 PM
Shepard's Avatar
Shepard
Wouldn't it do it anytime the drive belt was working, not just after it cut's out after the spin and it is slowing down?
Old Sep 18, 2003 | 07:20 PM
Shepard's Avatar
Shepard
We have had that noise as one of the clips on the dispenser is broken off. It is not that, however. Much louder and related to the spinning of the tub, but only when slowing down.
Old Sep 24, 2003 | 11:21 AM
Shepard's Avatar
Shepard
Well the Sears Washing machine, (made by Whirlpool), is fixed.
Had a bad transmission. Also the block on spin/agitator had worn through. Maybe not fully tightened at factory. Parts were covered under warranty even though it is 2-1/2 years old. I had originally thought it was 1-1/2 years old.
Repair man told us a couple of interesting things. The inside of the tub, under basket was very dirty and had gummy build up on it. I cleaned it off with some effort. Was told never to use liquid fabric softener in washing machines. Also was told never to use the smallest water level setting. Always use more water than you think is needed for size of load. Otherwise it is very hard on the transmission.
Old Sep 24, 2003 | 11:49 AM
Mil1ion's Avatar
Mil1ion
Good Timing
You ask this question the same day that *Gordon Jump* Dies.
He was in the Maytag Repair Man commercials.
Old Sep 25, 2003 | 03:48 PM
AlM's Avatar
AlM
fyi, for the future:
http://users.ev1.net/~oschmidt/Repair.html
Old Sep 25, 2003 | 06:11 PM
willowbilly3's Avatar
willowbilly3
We had a Whirlpool that washed 3-4 loads a day for 4 years with no problems. After we moved we got a used one and I have replaced the pump because the seal went out and also the plastic drive coupler, both of which I did myself. They are actually pretty easy to work on.
christaylor
May 10, 2005 04:16 PM
