2000 Ranger issue
Old Apr 3, 2018 | 12:32 PM
IWINGaming's Avatar
IWINGaming
2000 Ranger issue
Hi guys, i was hoping so of you might be able to give me some advice. On my way home from work my truck started to act like it was dying. I quickly turned off the heater, i dont know why i just did. When i did this it seemed to help but a few more miles down the road i turned it back on to see what would happen. I had no heat and then my truck started smoking really bad and i was forced to pull over. From what i can tell nothing came unhooked but i did notice that my coolant reservoir is no full and the lid was open. It was not like this when i left. Best i can tell is my engine evacted all of my coolant back into the reservoir. Any ideas? If anyone need more info just ask and i will tell you what i can. Thanks and have a nice day.
Old Apr 3, 2018 | 06:25 PM
mfp4073's Avatar
mfp4073
you say smoking? from where? What kind of smoke?
Im going to suggest you get one of those "carbon in the coolant" test kits and see what it reads.
oil in coolant? Coolant in the oil?
Something has pressurized the coolant system and pushed it out. Sounds suspiciously like a blown gasket that caused the coolant to run away and then an overheat condition. Thats really the best idea I have that fits the symptom you described.
Old Apr 3, 2018 | 10:44 PM
IWINGaming's Avatar
IWINGaming
No oil in the coolant as far as i can tell. I looks like i had a bad connection on one of the fittings for the radiator that probably cause the smoke. ( Coolant + hot engine). I know if i try to start it fluid is forced out of the radiator. I tested this by having the radiator cap off while trying to start it with only about a gallon in the system. I will be checking more things out tomorrow.
Old Apr 4, 2018 | 04:49 AM
mfp4073's Avatar
mfp4073
first step, refill and purge the system of air and see what it does.
you can also get a pressure tester that will give you more information.
Fordnandez
6.4L Power Stroke Diesel
Mar 6, 2019 09:42 AM
Mr Boogie
31
Feb 17, 2017 07:39 AM
Dlittle40
Feb 4, 2013 09:19 PM
biggercb
1997 - 2003 F150
Nov 19, 2012 10:36 AM
Mr. Bob
Dec 19, 2006 07:44 PM
