Cracked pedal assembly
Old Apr 3, 2018 | 10:36 AM
can0fspam's Avatar
can0fspam
The pedal assembly support on my 1983 is cracked through on the passenger side. It creaks and clunks when the clutch is used, and upon further inspection, I saw that the entire support flexes a lot as you push the clutch in.
I am looking to either repair or replace this part.
My question is, does anyone here have any experience with welding or otherwise repairing this part?
If repairing is not feasible, then I will pull a "new" one from a junkyard. Is there any information on year-to-year differences here? Can I use one from an '87-91?
Picture of the damage below, looking slightly upwards from the passenger side of the pedals.
Old Apr 3, 2018 | 11:59 AM
matthewq4b's Avatar
matthewq4b
Ya no repair of this part it is a low grade magnesium alloy get it any where near a welder and it burns.
You need to replace or find a mechanical way (fish plate etc) to fix it.
Old Apr 3, 2018 | 12:42 PM
can0fspam's Avatar
can0fspam
Darn. I guess I'm headed to the junkyard, then. I had visions of trying to fabricate a custom steel one, but I don't think that would be very easy.
Old Apr 3, 2018 | 03:00 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
E4TZ-2L252-B (replaced EOTZ-2L252-B & E1TZ-2L252-A) .. Brake & Clutch Pedal Bracket / Obsolete
1980/86 F150/350 & Bronco.
No Ford dealer or obsolete parts vendor has any of these three part numbers. There are none on ebay, either.
Old Apr 3, 2018 | 05:46 PM
Franklin2's Avatar
Franklin2
You can't use a 87-up pedal assembly, they do not fit correctly.
rudifisk
Jun 16, 2019 10:33 PM
Eddillard79
17
Mar 20, 2016 01:04 PM
52 5 star
May 2, 2011 12:01 AM
camodown
Ford Truck Parts for Sale
Oct 2, 2010 09:00 PM
DPhillips
Sep 23, 2010 10:17 PM
