Sponsored by: Real Truck
Window motor regulator perhaps ?
Old Apr 1, 2018 | 12:51 AM
12F350's Avatar
12F350
2012 F350, Drivers window intermittent , sometimes slow going down, sometimes normal. Sometimes it won't go up ( have to pull it up by hand, then motor will usually start raising it) . Sometimes it raises electrically just fine. I'm thinking the switch is okay .
Does this seem to be a regulator/motor issue ?
Old Apr 1, 2018 | 08:16 PM
Djosbun's Avatar
Djosbun
Sounds like the motor is bad, or the gear on the end of the motor is torn up. Replacing is not difficult nor expensive. Now if I was in your shoes, I would replace the window regulator while you’re in there, but only if you plan on keeping the truck for a long time.
— Dave
whateg01
16
Sep 14, 2010 10:16 PM
*2fords*
Jul 17, 2009 01:24 PM
Boz86
Nov 26, 2008 05:48 AM
1fordtruckman
Oct 22, 2007 07:44 AM
JFH
Mar 5, 2007 01:46 PM
