Gas smell problem
Old Mar 31, 2018 | 04:43 PM
sandymane's Avatar
sandymane
Gas smell problem
I have a fuel smell in the cab of my 94 when I come to a stop. I know diagnosing this online is difficult but I can not find it. I have NO leaking fuel. I have been all over the fuel lines and under the hood and can see nothing leaking. I have no codes. I have replaced the O2 sensor and the two fuel caps. I see no leaking injector. No smoke from tailpipe. Truck runs great. Anyone have any ideas where I can look for this issue? Thanks Sandy
Old Mar 31, 2018 | 05:23 PM
fordbozo's Avatar
fordbozo
Does this thing have one of those carbon filter jobs up under the hood? I think they call them the evaporate fuel cannister or something like that?
Old Mar 31, 2018 | 05:42 PM
sandymane's Avatar
sandymane
Yes, but I haven't smelled anything from it but I think I will pull it and see if gas is in it. Sandy
Old Mar 31, 2018 | 09:32 PM
sandymane's Avatar
sandymane
I just got checking things around the canister and purge solenoid area and finally noticed there is no purge solenoid. The line has been run directly from the canister to the throttle body. I know why I missed seeing it now, it wasn't there. I would surely think that is my cause but I am going to borrow the 95 solenoid and run it.
Old Apr 1, 2018 | 09:19 AM
Conanski's Avatar
Conanski
Some of these motors didn't have a purge solenoid so you won't be helping matters if you install one and there is no electrical connection for it.
Does your truck have dual tanks? If so do they both work? And even if they don't you could have the very common fuel transfer problem where the active tank pushes fuel into the other and overflows it out the filler tube and vapor canister system. Looks for evidence of raw fuel running down the outside of the tank filler tubes and for the presence of raw fuel in the vapor canister where there should not be any.
Old Apr 1, 2018 | 11:04 AM
sandymane's Avatar
sandymane
Just checked and the electrical connection for the 94 purge solenoid was neatly tucked away under the intake. From other things I have seen the PO was trying everything possible to get better mileage. It even had an oil separator he paid good money for that was advertised as a fuel saving device. So, I think some mechanic sold him on this too. I will hook up the 95 solenoid and see if it helps the 94 and let you know. Thanks for the reply. Sandy
Old Apr 1, 2018 | 01:32 PM
sandymane's Avatar
sandymane
Put the solenoid on and problem seems to be solved. Ran KOEO and still got 111 all clear. Thanks guys. Sandy
philly5eagle
May 15, 2007 10:59 AM
thomadm
Feb 18, 2007 05:29 PM
machinegreen
Aug 9, 2004 10:31 AM
Frank Kistner Sr.
Aerostar
Jan 10, 2004 07:02 AM
luke_trash
Sep 22, 2003 08:03 PM
