Trans ID
Old Oct 16, 2005 | 06:15 PM
captainkirk's Avatar
captainkirk
Trans ID
I found a transmission in a 1985 F150 with an inline six. It is a four speed with overdrive and it has a seperate bell housing for the clutch. Is there any particular way to ID the trans? How do you tell the New Process from the SROD if it is one of the two?
Old Oct 16, 2005 | 11:54 PM
85e150's Avatar
85e150
If the linkage is integral to the case, you have a SROD, Single Rail Over Drive.
If side mounted, SMOD, Side Mounted OD. These also go by several other names based on the RUG cast into them, or the number given them by Tremec. (Tremec 170, I think)
Here is some info on them:
http://www.davidkeetoploaders.com/imposters.htm
These use the same design as an old Top loader car trans. They were built by Tremec for Ford. Not as strong as a top loader. 2nd to 3rd is too much of a jump, making for tough sledding if you are in hills or curves between 30 to 50 mph.
A NP box will have a top mounted shifter and be low first with direct 4th.
Old Oct 17, 2005 | 03:50 PM
captainkirk
Thanks for the info. It has a top mounted integral shifting mechanism. Is there a hurst or B&M shifter for this trans? What is the torque capacity?
Much appreciated.
Kirk
Old Oct 18, 2005 | 02:09 PM
85e150's Avatar
85e150
Top mounted shifter, aluminum case, rail housing visible on driver's side, right?
These were put behind 300s and 302s. Not sure of the limits of this trans.
Seems like I looked for a shifter once and found nothing from the aftermarket.
snowmanbs
Oct 30, 2013 09:27 AM
17fordguy
Dec 24, 2007 05:44 PM
vantage2
Mar 9, 2002 11:03 AM
AlM
1978 - 1996 Big Bronco
May 31, 2001 11:03 AM
