U-joint alignment
Old Mar 29, 2018 | 08:50 AM
john jamieson's Avatar
john jamieson
U-joint alignment
I thought I read somewhere that there is a proper orientation for the u-joints when installing a drive shaft. Is there or does it not matter on a stock ride height truck? This is for my '66 with a 2-piece drive shaft.
Thanks.
john
Old Mar 29, 2018 | 08:59 AM
willowbilly3's Avatar
willowbilly3
There is a proper installation. drive shafts need to be phased or timed so all the crosses are in the same plane. Also if using greasable joints, the zerks (almost) always point out, or toward the ends of the shaft. This is mostly so you can get a grease gun on the fitting. Also for maximum strength, crosses should be installed so the grease fitting hole is in compression under torque.
Old Mar 29, 2018 | 02:20 PM
Crop Duster's Avatar
Crop Duster
Drive shaft
Here you go.
Old Mar 29, 2018 | 10:35 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
3) C5TZ-4635-F .. Combination U-Joint - Use with two piece driveshaft / Spicer # 210392-X / 2 cups are 1310's; 2 cups are 1330's / Obsolete
1965/79 F100; 1975/79 F150.
NOS PARTS LTD in Waxahachie TX has 13 = 972-937-2201.
RPN PARTS in Erie PA has 15 = 888-864-9305.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 18 = 800-476-9653.
GREEN SALES CO. in Cincinnati OH has 66 = 800-543-4959.
Old Mar 31, 2018 | 07:16 PM
john jamieson
Thanks for the help everyone. I hope to get to them this weekend.
AZ66F100
Oct 1, 2017 02:19 AM
79F250isalive!
Jan 15, 2015 08:24 AM
63flareside
Dec 6, 2012 09:12 PM
Bad Bad Leroy Brown
Oct 22, 2012 07:28 PM
airharley
Aug 28, 2007 02:08 PM
