Towing Tune
Old Mar 28, 2018 | 11:46 PM
Bhead's Avatar
Bhead
Towing Tune
Just wondering what your thoughts are on buying a tuner for use when towing? Are they worth it?
Thanks
Old Mar 29, 2018 | 09:01 AM
Toyman's Avatar
Toyman
What are you towing with? Some vehicles can benefit from them, others not so much.
Old Mar 29, 2018 | 09:14 PM
Bhead's Avatar
Bhead
Thanks. I have an 05 6.0L Excursion 4X4.
Thanks
Old Mar 30, 2018 | 06:58 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
With that 6.0, if you haven't replaced the torque-to yield head bolts with studs, do NOT tune your SUV.!!. A tune could cause the head bolts to stretch and cause major engine damage. Go to the 6.0 diesel forum and request info.
Old Mar 30, 2018 | 07:11 AM
Toyman's Avatar
Toyman
Definitely what Bud said. The 6.0 does respond really well to tuning, but the headbolts do not like the extra pressure. In fact even with out a tune the headbolts will stretch if you tow heavy and/or often. Once a few (expensive) things get swapped out they are awesome!
Old Mar 30, 2018 | 12:47 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
True that Rich.... exactly why Ford had to replace mine under warranty... I just had a set of studs right there when it happened and the mech used the studs instead of the bolts when he re-installed the heads....and the oil cooler AND the EGR valve.
Old Mar 30, 2018 | 01:40 PM
Toyman's Avatar
Toyman
That's perfect timing! I would love to find a nice clean Excursion to haul the boat with, but the thought of having to pull the motor to do studs doesn't sit right. Maybe I'll find one in a few years that has already been done......
Old Mar 30, 2018 | 01:56 PM
Stewart_H's Avatar
Stewart_H
I have a bit of a differing opinion. Mine is Yes and no, depending on your situation.
Lotta guys have had good results using DI's non-studded tunes for their 6.0 with the CTS-2. That's what I run in my non-studded 6.0 and I do NOT drive like a grandpa. I race NHRDA with my work trucks, but I haven't raced the 6.0 yet because I have a drivers side 4x4 hub situation I need to correct first. But if you've seen me drive, every freeway on-ramp is a reason to stretch the 'ol girls legs out!
Stewart
Old Mar 30, 2018 | 03:25 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Sure, no problem "stretching legs" - just don't be towing heavy while doing it !!
Old Mar 30, 2018 | 06:40 PM
Stewart_H's Avatar
Stewart_H
No, of course not....
Side note: ....remind me to tell you the story sometime about my 7.3L and a semi 18-wheeler, while towing....
....but I do tow with it with my non-studded tunes. I just don't beat on it when it's hooked up.
Stewart
Old Mar 31, 2018 | 11:13 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
7.3 and the 6.0 are very different engines too.
Old Mar 31, 2018 | 11:53 AM
Stewart_H's Avatar
Stewart_H
Tell me about it.
Wanna help ease up the aggressive driving a tad? Go from a 7.3 to a non-studded 6.0! LOL!
I woulda never done what I did with my 7.3 to my 6.0, but I actually forgot I was pulling my 31' TT when I was ummmm, merging onto the freeway from a long, sweeping onramp.
Stewart
Old Mar 31, 2018 | 12:45 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Actually, comparing my 60 (studded) with and without the tow tune there really isn't much difference. Oh yeah, using the tune does help the getting up to speed better - but not THAT much and at the cost of higher fuel consumption. Now if I use the street tune vs not (without towing) WOW !!!
Old Mar 31, 2018 | 01:39 PM
Toyman's Avatar
Toyman
I believe the biggest benefit from the tow tunes is the trans shifting firmer and holding into higher rpm's before shifting. It does add some fuel delivery stuff from all of them I have used, but the benefit is for the trans.
Old Apr 1, 2018 | 05:27 AM
WE3ZS's Avatar
WE3ZS
Just get an EX with the good motor, you know the one with more cylinders!
efiguero
Jul 13, 2018 11:30 PM
Flaman
Feb 19, 2017 08:01 AM
sgc2c
Jun 14, 2014 08:49 PM
EddieEX10
Oct 22, 2013 09:45 AM
slorider
Jun 3, 2010 05:24 PM
