Does my 360 have bad rings?
Old Mar 28, 2018 | 07:19 PM
Agnew's Avatar
Agnew
My 360 is smoking out of the driver side valve cover BAD. The passenger side smokes a little bit too but theres no excessive smoke out of the exhaust. I also have milky sludge on my valve covers.. Over the winter I put in a new cam and a 4 barrel manifold. I'll be trying a new PCV valve soon. What do you think is going on? Rings? Bad intake gaskets? Will a PCV help?
Old Mar 28, 2018 | 09:58 PM
dodmort's Avatar
dodmort
Intake gasket my guess....(Oil and Water mix)
Old Mar 28, 2018 | 11:39 PM
sawmaned's Avatar
sawmaned
oil/water
i second,the oil water mix,did this start after you did cam and intake,after you swapped cam and intake did you change the oil ?.
Old Mar 29, 2018 | 09:53 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
The exhaust crossover port at the intake may be leaking. They tend to get really corroded making the gasket seal almost impossible.
Old Mar 30, 2018 | 08:31 AM
baddad457's Avatar
baddad457
Milky sludge ? You've got a coolant leak or a blow head gasket
2_Tone
Nov 12, 2016 03:02 PM
66flareside
32
Mar 31, 2006 07:28 AM
gtex
29
Feb 25, 2005 12:23 PM
69highboy
May 14, 2004 10:05 AM
BigBrownTruck
Feb 29, 2000 12:53 PM
