Exhaust
Old Mar 25, 2018 | 05:08 PM
acknott's Avatar
acknott
4wd Low
Exhaust
I have to completely replace my exhaust because the PO hacked it together, will 2.25" duals be fine? I would be using an X pipe so it wouldn't be straight "True" duals
Old Mar 25, 2018 | 05:30 PM
rla2005's Avatar
rla2005
If you feel compelled to have two of everything, then yes a 2.25" exhaust plenty for a stock engine.
Old Mar 25, 2018 | 05:42 PM
acknott's Avatar
acknott
4wd Low
I already have all the bends and pipe to run from the headers down to where the Y collector would go just not sure if I want to put an X and two Mufflers or just the Y. Engine is Bored .30 over and has a mild cam + 6 liter tune up other than that it's stock
Old Mar 25, 2018 | 06:42 PM
Conanski's Avatar
Conanski
Save your coin and just do a single 2.5" system.
Old Mar 25, 2018 | 06:45 PM
acknott's Avatar
acknott
4wd Low
Still doable, would just use a y instead of an x. They dont make the muffler i want in 2.5" though lol
Old Mar 25, 2018 | 07:12 PM
Conanski's Avatar
Conanski
What "muffler" is that?
Old Mar 25, 2018 | 07:20 PM
acknott's Avatar
acknott
4wd Low
Flowtech Purple Hornie. I have them on my 65 stang and i really like them on the 289
Old Mar 26, 2018 | 04:09 PM
TexasGuy001's Avatar
TexasGuy001
I decided to retain a single exhaust when I redid mine. I went with 3 inch thought it would be the best setup for future motor plans. It is my understanding that single works better in these trucks. I've known people with Ford, Chevy, and Dodge trucks of this era that converted to true dual exhaust and saw fuel economy drop.
I also have a vintage Mustang. Are you on VMF?
Old Mar 26, 2018 | 04:52 PM
acknott's Avatar
acknott
4wd Low
I am not, and thanks for the reply! I have a week or 2 to decide, im not sure which way to go
Old Mar 26, 2018 | 05:26 PM
EllieMae94's Avatar
EllieMae94
After getting a lot of recommendations from this board when I put on a new exhaust last year I ultimately decided on long tube headers into a "y" and 2.5" the rest of the way back along the passenger side. This is what most members here do with these trucks and can say I am pleased with how everything turned out. A 3" single is also a good idea, but I'd forget about an X pipe and dual exhaust. Good luck with whatever you decide.
Old Mar 26, 2018 | 05:30 PM
acknott's Avatar
acknott
4wd Low
Thank you for all of the replies!
Old Mar 26, 2018 | 06:35 PM
95fiveoh's Avatar
95fiveoh
I'd put a single 2.5" and dump it right in front of the rear tire. It's a simple, cheap setup and works flawlessly.
Old Mar 26, 2018 | 09:39 PM
TexasGuy001
I suggest finishing the system out completely with a tail pipe. I've had turn down exhaust under the bed and it is just something that gets annoying after a while.
79Ranger250
May 14, 2014 12:02 PM
turtle13b
Mar 19, 2010 01:32 AM
62Cole
Mar 2, 2006 04:33 PM
77fordguy
Exhaust Systems
Jul 20, 2005 03:46 PM
truckzilla
Jan 30, 2002 10:40 AM
