Question on late model engine swap
Question is on fuel though for this post. I'm looking at reusing my stock manifold and stock carb, its a 351 CFM 2V ford carb. Same carb found on my 351W in my '78 Mercury. So I want to say that the carb is big enough for use on a 302 from a '96 Explorer with the GT40 heads. Especially considering the head specs I found show they are 145cc intake runner with a 63 - 66 cc chamber and a 1.85"/1.54" valves.
But I wanted to ask those on here that might know better on how well of a match would it be?
Its a stock reman engine and I will be reusing the stock components from my truck such as exhaust manifolds. So there wont be any hot rod parts in her unless the cam is not a roller explorer cam that everyone has told me to go with. I might consider doing a 1.7:1 rocker upgrade like I was told to do to build the most bottom end torque.
None the less I am trying to make a list of parts I will need to buy and need to know if my stock carb and intake would work perfect on this setup with no problems.
