Sponsored by: Real Truck
Electrical issues, frame ground?
Old Mar 25, 2018 | 09:26 AM
Jeff Tarantino's Avatar
Jeff Tarantino
hello, I’m new to this forum. I have a 04 6.0 f350 CC LB. recently replaced the rear crossmembers on the frame. Peeled back the wiring harness off the frame and we had to weld a nut to the rotted ground bolt for the frame ground off the harness. ( expert welder helped in the welding department) ever since then, I lost my entire cluster except the abs and check gauges light. No pwr windows, no radio, no dome. Swapped out for a known good cluster, and I got back my radio, windows and most of cluster. No tach, speed or temp gauges. Also no dome until I take the key out of ignition. I’ve searched high and low for a wiring schematic of the frame harness to see what that ground feeds. I’ve tried grounding to several different locations figuring I didn’t get a good ground, now I’m getting the impression we fried something from welding to the ground. Looking for some insight or at least a wiring diagram for the frame harness. Thanks guys!
Old Mar 25, 2018 | 11:36 AM
FiznUKa's Avatar
FiznUKa
Old Mar 25, 2018 | 12:11 PM
ligito's Avatar
ligito
I hope you removed the ground cable from the battery, before welding.
191124x7
Jan 11, 2019 02:40 PM
tdl0
Electrical Systems/Wiring
Sep 10, 2016 12:44 AM
sunbelt57
Apr 8, 2015 04:31 PM
JKfordfan
Sep 10, 2006 07:15 AM
