HEI Distributer
Old Mar 24, 2018 | 09:46 AM
gatorjaws's Avatar
gatorjaws
HEI Distributer
Installing the HEI kit I bought off ebay on 1963 f250 4x4 y block. Putting on the cap there is a gap in the housing where the vacuum canister attaches that the cap does not cover.Is this an issue? Am I doing something wrong? I see in the kit wher if I switch to mechanical advance there is a piece that covers the gap.
Whats the best setup for me? This f250 is geared pretty low and top end is around 60 mph.
Old Mar 24, 2018 | 10:29 PM
Capjack01's Avatar
Capjack01
my two cents:
keep the vac advance. unless you're really pushing the limits on a street motor where all the valve and ignition timing has to be dead on predictable to 7k rpm or higher (primarily a race motor). the vac advance does a ton for keeping it driveable and smooth.
as far as the HEI cap. some pics would be a big help if possible. most distributors seal pretty well to keep moisture out, so a gap "could" be an issue in bad weather.
Old Mar 24, 2018 | 11:39 PM
gatorjaws's Avatar
gatorjaws
hello, how do I post a picture to the thread?
Old Mar 25, 2018 | 07:26 AM
Jolly Roger Joe's Avatar
Jolly Roger Joe
If you have the pic on your computer, select the Picture icon
Browse your device for the pic, select it and upload it.
If the pic is on the world wide web, copy the URL and paste it into the top line of the picture add screen.
Old Mar 25, 2018 | 11:38 PM
gatorjaws's Avatar
gatorjaws
Old Mar 25, 2018 | 11:40 PM
gatorjaws's Avatar
gatorjaws
I figured it out (posting pic) I think. will send distributor pic soon
Old Mar 26, 2018 | 01:30 AM
Tedster9's Avatar
Tedster9
Y Blocks like lots of advance. OEM initial advance is probably 3° BTDC, most folks run around 12°, you'll have to play around with it a bit to get it right. Something around 34° to 38° "total" advance "all in" would be what you want, before 3000 RPM. Set the distributor wherever it needs to be to get this number. This is without vacuum advance connected. Keep adjusting till the curve is how you like it, then leave it alone.
Then re-connect vacuum advance. This is adjusted separately or independently of the distributor timing.You want vacuum advance, it will help the engine run cooler and smoother and is good for a couple extra MPG.
Top_Speed1
All Things Towing
43
Aug 16, 2021 10:29 AM
benbuilder
Mar 6, 2017 09:53 AM
GamerGirlAlice
Sep 13, 2013 07:50 AM
68cabby
Mar 18, 2013 08:31 PM
TickTock
Jan 8, 2012 02:10 PM
