Strange
Old Mar 25, 2018 | 01:16 PM
Robert Long's Avatar
Robert Long
Didn't think of gas cap, still has the originals on it, thanks for the info.
Old Mar 25, 2018 | 02:08 PM
rla2005's Avatar
rla2005
Originally Posted by Robert Long
4&8 yes only codes are 111 and 10 on ether computer. Could the code reader be bad ? A friend is bringing his over this afternoon, guess I'll know then,
Many code readers interpret the separator flash as Code 10.
So just to be sure: you are getting Code 111 (twice) for KOEO, then Code 10 (separator flash), then Code 111 (twice) for Stored Code display?
Old Mar 25, 2018 | 02:11 PM
Robert Long
Yes, sorry I wasn't clear on that.
Old Mar 25, 2018 | 02:13 PM
rla2005's Avatar
rla2005
A 1995 OBD-I vehicle has no way to monitor whether the gas cap is on or off or loose. That is not a consideration here.
Old Mar 25, 2018 | 02:17 PM
rla2005's Avatar
rla2005
If you remove the reader before the KOEO tests and CM codes are completely displayed you will clear The CM codes.
Old Mar 25, 2018 | 02:18 PM
Robert Long
Thank's that should save a few dollar's, Buddy just called, on his way with his reader, maybe it will tell us something.
Old Mar 25, 2018 | 02:57 PM
rla2005's Avatar
rla2005
The Keep Alive Memory (KAM) power comes into the PCM on Pin 1. If the circuit is open the CM codes will be dumped every time you shut off the ignition. That is the only way I know of to have an active CEL, but no stored codes. Especially given you put in a different computer.
Code 512 ( EEC battery powered Keep Alive Memory (KAM) test failed.) will be triggered if the KAM circuit is open, but it's stored in CM so it's a chicken and egg syndrome.
Old Mar 25, 2018 | 03:34 PM
Robert Long
Thanks Rla we'll check that.
Old Mar 25, 2018 | 04:26 PM
Robert Long
Thanks again rla, found wire on the plug just hanging by a couple of strands, fixed that and took it for a drive, now both readers give a 571. Not sure we would have found that without your input! Thanks again!
Old Mar 25, 2018 | 04:49 PM
rla2005's Avatar
rla2005
Glad you found it. Multiple problems are tough to deal with.
Old Mar 25, 2018 | 04:53 PM
Robert Long
Thanks to you and everyone here, we found it in record time.
F450 Aaron
Aug 8, 2007 04:04 PM
cjben
General Automotive Discussion
Nov 20, 2005 02:16 PM
Jim59
Oct 21, 2005 05:07 PM
mixer94
Jul 19, 2003 07:35 PM
damian
1997 - 2003 F150
May 2, 2003 09:38 AM
