Switch Bezels
Old Mar 22, 2018 | 09:42 AM
CharlieLed's Avatar
CharlieLed
Switch Bezels
I am looking for a couple smooth switch bezels. If I had a lathe I would turn them myself but I am sure that someone else has either done it already or has far more skills on the lathe than I. I have a 56 light switch and an aftermarket wiper switch (came with the replacement electric wiper setup) that I would like to have a matching set of bezels. If anyone has a source for these bezels I would appreciate a point in the right direction. Here is a sample of a bezel:
Old Mar 22, 2018 | 10:02 AM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Hi Charlie.
Is this what you're looking for?
https://www.macsautoparts.com/ford_t...nd-lights.html
Old Mar 22, 2018 | 10:26 AM
CharlieLed's Avatar
CharlieLed
Thanks Joe. The stock bezels are what I am looking to replace. I am looking for something like a turned billet aluminum bezel with no engraving.
Old Mar 22, 2018 | 12:25 PM
Jolly Roger Joe
Sorry, after I reread your first line, I see you want them "smooth" without the labels.
Old Mar 22, 2018 | 03:55 PM
ALBUQ F-1's Avatar
ALBUQ F-1
What are the cable housing dimensions? Check out the marine sites:
https://www.eddiemarine.com/shop/was...colored-finish
https://www.eddiemarine.com/shop/was...color-finish-1
Do you need the "D" shaped center opening?
Old Mar 24, 2018 | 12:02 PM
CharlieLed's Avatar
CharlieLed
That is a good source Ross, unfortunately those washers are a bit too small for what I need. One thing that I did see about those washers is that they would be perfect for rear fender bolts...maybe a little thick but easily sanded down to size. I am not concerned about the "D" center hole since there will be no engraving then there will be no need to index them to the switch. Thanks...
WRCR
Jan 28, 2019 07:46 AM
chad77
Oct 3, 2016 07:42 PM
GeneStoner
May 12, 2004 11:25 AM
D Ray
Aug 19, 2002 12:50 PM
