MAP sensor location / mounting
Old Mar 21, 2018 | 08:03 PM
GoldCo's Avatar
GoldCo
‘95 5.8 going in ‘52 F3.
On the donor 95 sensor was mounted via a funky bracket hanging off/away from firewall. Can I mount it directly against either firewall or fenderwell closer to radiator w/o bracket? Has two nice tabs built-in and I’m going for a cleaner look.
TIA
Old Mar 21, 2018 | 08:04 PM
GoldCo's Avatar
GoldCo
Old Mar 21, 2018 | 08:34 PM
Conanski's Avatar
Conanski
You can put it anywhere you like, the only requirement is that it be connected to manifold via a vacuum line.
Old Mar 21, 2018 | 10:33 PM
GoldCo's Avatar
GoldCo
Thanks.
JustinInOregon
Oct 31, 2018 06:56 PM
Bryan Hagan
Nov 25, 2016 11:32 PM
xc4jokestomper
Jun 10, 2011 12:04 PM
cpettymore7777
Apr 20, 2011 07:32 AM
The Man
Aug 14, 2005 11:38 AM
