I installed superlifts add-a-leaf and now my 97 F-250 HD is 1/2 in. higher up frount witch is fine for me did but stifen up the ride some. Someday I will be swapin out the TTB for the F-350's Dana 60
Originally posted by Quadzilla When I first put my kit on, the front raised a little more than 3", which put it slightly higher than the rear. After driving it for a little while, it settled a bit, and now sits perfectly level. I add about 30psi to my rear bags to give it a slight rake.
I haven't had any issues with alignment since adding the kit.
what kind of bags do you have in the rear? do you like em? where did you get em?
