Power steering line seals
When I did my steering gearbox one of the hoses was done since last time someone ultra tightened it. Anyways I bought an aftermarket hose deffinetly looked like a downgrade but nothing else to do with the surprise replacement on the low pressure line. I kept the original other hose and “replaced” the seal after going to 10 stores and even a seal shop with a seal as the logo everyone had the same kit. There is a tiny leak from that new seal my motorcraft warranty geargbox arrives today and I want to stop the leak as tiny as it is. Has anyone bought new rings for these I think I read the a/c style will work the original one was kind of shaped like the fuel filter o ring. If I can’t find a solution I’ll probably end up having to buy another aftermarket as I don’t have time to wait for shipping and ford so they don’t make those anymore.
Thanks
Thanks
Thanks
Thanks
Not sure about only the seals, but I replaced my high pressure line from the pump to the hydroboost with the line NAPA carried. I couldn't tell the difference between it and OEM. My leak wasn't at the seal though. The middle of the hose was leaking slowly so I had no choice but to replace the whole line.
https://www.ford-trucks.com/forums/1...l#post17827986
I have replaced my high pressure line several times, twice with one from the box auto stores and once from the Ford dealership. I noticed the Ford line was of better quality especially there at the pump connection. The o-rings and teflon seal do not get torqued very much at all and I think that is a precursor to early failure, typically at the pump. I designed a hose from the hydraulic shop that uses a stainless flex, teflon lined braided hose with fittings to adapt to the pump side and then directly to the hydro-boost. I've had it on the truck now for a couple of years and think this will eliminate any failures within at least five or more years. I recently gave gave the info to a friend with an Excursion to do the same. I do carry the new Ford line as a back-up with the appropriate original fittings that can be replaced fairly quickly in an emergency if required. Cost for the hose complete was around $65 depending on the length of SS braided hose. My buddy and I think this is a bullet proof design compared to the after market junk we see. I present I had pics on my phone and will try to retrieve them from the failed phone and post them in my albums in my profile.
You are correct timmyboy76, I used a swivel type 90 degree fitting with an 0-ring. This allows you to rotate the 90 so that it pretty much clears the tube. You may need to zip tie the tube to assure no contact with the fitting. I have the insulation removed from my tube so that helps some.
I have just reinstalled 2 different pump to boost pressure hoses 2 times each and they both leak between the dang nut and tube at the pump fitting! Maybe I'll try an AUtoZone line and return the Napa and AC Delco lines if it's any better. The AC Delco leaked like a sieve and the Napa tube bend pushed the hose on the shock tower and leaks from the o-ring if there is any radial pressure on it in any direction.
I know it's a lot to ask, but I'm almost at my wit's end having done this so many times now.
Yes if someone has the details that would be great. I started this thread about the 2 low pressure lines. I recently replaced the high pressure one built from autocrap then about 30k later the hose exploded at the pump again on the highway to kick off my 10 hr road trip. One uber 50 bucks and my tools later I was back on. It’s one month since I’ve had the Napa line and plan on replacing it on or before the year mark. I don’t want to say a 3rd time put crap on in a pinch than paid x2
For anyone else in the meantime: I was able to get mine to stop leaking (for now) by rotating the hard line out of the pump clockwise enough for it to stop pushing the soft line against the shock tower.
Any more info on this? It turns out my fix only worked while the truck sat in the driveway. 2 different new HP lines and both leak between the nut and tube.
Are you talking about the nut that is into the plastic (green below), or the captive nut on the end of the high pressure tube (goes where the red plug is below)?
Do you know the threads into the hydroboost? I'm assuming this replaces the 90 degree hard line coming off the hydroboost? If not, maybe I should just take one of the new leaky lines down to Motion & Flow Control and have them build a direct replacement for just the high pressure line.
