notes on gauge install, Isspro EV2s
Old Mar 29, 2018 | 09:27 AM
HermannF350's Avatar
HermannF350
Originally Posted by oldbird1965
I run one in each manifold that is drilled and tapped. In the up-pipes, yes about 100° cooler. In the DP about 200° cooler.
How accessible is the driver side manifold?
I am somewhat hesitating of drilling into the exhaust without making sure to remove all the debris though, the last thing I want is a broken turbo.
On the other hand I also don't want to remove the up-pipes since mine aren't leaking (yet)..
I was thinking of tapping into the y-collector but I don't know how good that can be done.
Old Mar 29, 2018 | 11:09 AM
Hit Man X's Avatar
Hit Man X
My old 6.4 PSD used an uppipe mounted thermocouple from the factory. Worked fine there.
Dual units would be smart, could help show if one bank is significantly hotter than the other amd alert to a fueling issue.
Old Mar 29, 2018 | 01:22 PM
oldbird1965's Avatar
oldbird1965
I used a lot of grease on the drill bit when drilling into the exhaust manifold and used a small magnet thru the hole to make sure there wasn't any filing left in there. Collector? Good luck getting to that to drill a hole. If the up pipes aren't leaking I would leave them alone. Easy to get at, drill into the bend towards the rear. There are pictures around here someplace.
I used a isspro in the drivers side manifold and a glow shift in the passenger side. The isspro runs 100° hotter then the isspro. I contribute that to the two different brands but IDK for sure.
Old Mar 29, 2018 | 01:38 PM
kmjone00's Avatar
kmjone00
The area around the driver's side manifold is a little tight but reachable. I unplugged the block heater for more room. Based on some recommendations I read, I marked the manifold for where I wanted to drill first, and spent a few minutes before drilling just aligning the drill and bit to make sure I had a comfortable approach to drill a nice straight hole. I wouldn't mess with the up-pipes and collector if they are not leaking. Based on what I've read the driver's side manifold is the nearly universally agreed upon location for the probe.
I love the idea of dual EGT gauges. However decided to go with just one just to get the project rolling. Figured these three would get me most of feedback from the truck I need most of the time.
Question for folks who know more than me: If you had a performance problem that dual EGT gauges would indicate, would you have some other indication as well, such as a noticeable miss, or a failed contribution test? Or would you get noticeably different bank temps long before you ever failed a contribution test or noticed a miss?
Glen thanks for the info on the rough estimate temp drops from manifold to collector to downpipe, good info. And yes, grease on the drill bit, thanks for adding. I put a vacuum hose up on the manifold too after drilling to try to pull any shavings out. Magnet is a good idea too. Interesting temp difference on the two different gauges.
Old Apr 2, 2018 | 10:28 PM
Badfrog1's Avatar
Badfrog1
Originally Posted by kmjone00
I recently installed gauges in my truck. I assume this upgrade is a pretty straightforward task for most folks here. However I had not installed gauges before, other than my Aeroforce scangauge, so I needed to do some research first. The process is pretty well documented between write-ups on the internet and install instructions from various vendors. However there were several small steps where a picture would have really helped clarify the process for me. So I took pictures during my install and thought I would post here in case it helps any other entry level folks like me.
I used Isspro EV2s, primarily because I thought they would match the factory gauges, and an Autometer pillar pod. I did the usual pyro/EGT and boost gauges, and went with a fuel pressure gauge for my third since I have a ZF5 truck (therefore trans temp is not a major concern). I got the snubber kit for the fuel pressure gauge, and I installed the gauges with the potentiometer dimmer that Isspro offers to enable me to brighten or dim the gauges as needed to match the factory cluster. It’s worth noting, this potentiometer enables you to both use your factory dimmer to adjust brightness of the gauges AND adjust them up or down additionally if their relative brightness does not match the factory cluster. I did not understand this at first and assumed the factory dimmer would be sufficient. But it seems the gauges are often X percent brighter (or dimmer) than the factory cluster, so just adjusting brighter or dimmer would always maintain that percent difference between the new gauges and the factory cluster.
The aspects of the install where I could have used more clarity were:
1) Fittings needed to make a T for the MAP
2) Exact location of hole for EGT probe
3) Fuel pressure sensor fitment on the factory fuel bowl
4) Where to route wires into firewall
5) How much to drill factory A-pillar trim piece
6) Good location for Isspro dimmer
7) Basic wiring and power sources
Forgive me, I know this is really basic stuff for a lot of folks here. Photos to follow...
Thanks for your detailed write-up. I am in the planning stages of replacing some old aftermarket gauges; I had not looked at the ISSPRO gauges but I am now!
Old Apr 4, 2018 | 01:38 PM
Talyn's Avatar
Talyn
I just ran my boost gauge into the y-pipe, so much easier.
Old Apr 4, 2018 | 05:00 PM
Jarrett Campbell's Avatar
Jarrett Campbell
I've got a pre-tapped port in my spyder. Thanks E99 Intercooler!
Old Apr 4, 2018 | 09:14 PM
kmjone00's Avatar
kmjone00
Yes I agree, having done it now, just drilling and tapping the y-pipe would have been simpler. But really my only complication with using the T into the MAP sensor hose was not knowing exactly which fittings to get. If you know what to get then this approach is really no trouble either. I just didn't want to mess the factory piece up. I wanted to keep as much as possible the way it was from the factory...so using existing holes, drilling as little as possible, etc.
Intercooler is on my to-do list. Seems like the E99 spyders are getting harder to come by.
Old Apr 8, 2018 | 11:56 PM
Badfrog1's Avatar
Badfrog1
Great write up and nice looking finished gauge install... I really like the gauges. How do they look at night?
Old Apr 9, 2018 | 08:29 AM
kmjone00's Avatar
kmjone00
Thank you sir. I'm pleased with the lighting at night. I have a couple pictures, will find a decent one and post.
Old Apr 11, 2018 | 10:48 PM
kmjone00's Avatar
kmjone00
Here you go, here's a couple pictures with the lights on...
Lights near dusk.
Lights. Green is a close match to factory. White needles are a little brighter.
Old Apr 11, 2018 | 10:52 PM
kmjone00's Avatar
kmjone00
Wow, pictures came out huge this time. In case it helps anyone, I put them in with the pyrometer gauge on top, boost in middle. fuel pressure on bottom. My fuel pressure was low in these pictures (before shimming FPR with BB).
Old Apr 12, 2018 | 12:20 AM
  #28
Badfrog1's Avatar
Badfrog1
WOW! Those look great! The visibility is amazing. So many gauges are “busy”...
I’m sold!
cyclone-429
36
Jan 28, 2017 09:18 AM
eakermeld
Feb 3, 2015 06:47 AM
FossenRacing
Apr 4, 2013 06:20 AM
PaysonPSD
60
Apr 9, 2011 09:17 PM
MustangMatt96GT
Feb 19, 2011 11:38 AM
