Fifth wheel bow broken?
Old Mar 20, 2018 | 07:48 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Old Mar 20, 2018 | 07:49 PM
bigredtruckmi
Veteran: Navy
What do you guys think? It goes in on Thursday
Old Mar 20, 2018 | 08:45 PM
scraprat's Avatar
scraprat
Top Answer: 5
It looks like possibly the wall studs have broke from the frame causing side flex in the corner.
Old Mar 20, 2018 | 08:48 PM
bigredtruckmi
Veteran: Navy
Will see how good the extended warranty is. They covered another problem with no cost to us.
just couldn’t figure out the outside problem in same area
Old Mar 20, 2018 | 08:56 PM
senix's Avatar
senix
That looks pretty much like it came loose
Old Mar 20, 2018 | 09:00 PM
senix's Avatar
senix
I think they will have to peel the outer skin off to see what it wrong with it.
Then they are going to have to address the inside wall. I would have them check the carpet and flooring
Old Mar 20, 2018 | 09:01 PM
bigredtruckmi
Veteran: Navy
The service tech is great. He has repaired several things over the years on this rig. We got a 7year extended warranty thank goodness
Old Mar 20, 2018 | 09:10 PM
bigredtruckmi
Veteran: Navy
In looking underneath. Nothing looks like a problem but it is above the floor
Old Mar 20, 2018 | 09:11 PM
senix's Avatar
senix
Well that is good, but looking down at the carpet I think it is suspect. Maybe just the lighting in the pics?
Old Mar 20, 2018 | 09:13 PM
bigredtruckmi
Veteran: Navy
Yes flash didn’t turn on so probably a shadow which it looks like. I was after the wall movement. This was the pics I sent to dealer.
Old Mar 22, 2018 | 04:54 PM
bigredtruckmi
Veteran: Navy
Got call from dealer. Many screws sheared off was the problem. Must have been the nice smooth roads.. not covered by extended warranty
Old Mar 22, 2018 | 05:10 PM
golfmedik's Avatar
golfmedik
Damn, if they need grade 8 bolts then it looks like it should be a warranty problem if the bolts they put in do not hold up. But, that's just me...
Old Mar 22, 2018 | 05:17 PM
bigredtruckmi
Veteran: Navy
If we head south. We I’ll go I75 the whole way even though it is longer route for us. We had the rough roads coming back via I 24 and I 65 and 69
Old Mar 24, 2018 | 03:04 PM
69cj's Avatar
69cj
If they won't cover under warranty, did you try your ins. carrier. Long shot but maybe?
Old Mar 25, 2018 | 12:59 AM
kgburns's Avatar
kgburns
You think your damage might have been caused by that rough section of I-65 at Birmingham? If so, there is a way to avoid that, only adds about 20 minutes to the driving time
