I am getting to the point of buying a new box, because MN. I am to put in a gooseneck/fifth wheel solution around the same time, so I only have to lift the box off once. My question is, does anyone know what is different between on 05 F350 cclb and a newer truck? Specifically why won't a newer factory 5th wheel / gooseneck hitch bolt on to an 05? If anyone is in the process of putting one of these kits on I would love to get some measurements from you.
Thomabb, do you happen to know exactly what changed with the frame/crossmembers? I have been looking at as many frames as I can and I can't see what is different yet, my guess is it will come down to a small difference in measurements but idk.
Save yourself the headache and go to the B&W system. You can find them used for around $250.00 or so for the frame mount and ball. The 5th wheel companion is about the same price as a Ford factory unit.
I don't know what the exact changes are. At some point Ford started pre-drilling the holes in the frame for their crossmember. They also started pre-dimpling the beds for the hole locations. Probably all minor changes, since the beds are mostly interchangeable across so many model years.
So I know for sure that the holes in the top of the frame are not there. They would have to be drilled. The holes in the side of the frame, I'm not sure of, but I think they would have to be drilled as well. On another note, does anyone know how close the king ranch maroon/ beige from 05 matches the king ranch maroon beige of 11? If they are an exact match (which I don't think they are) I would definitely push forward with installing the ford factory setup because I have found a perfect bed that would be a color match. If they don't match I think I am going to go a different route.
Thanks,
Baatzy
the paint code code is what you need
its on your door sticker
for the donor bed, lookup the year and color and see if it is the same paint code.
its a 2 digit code. Mine is UD which is ebony gloss black
I tried this, but unfortunately Ford changed paint codes in between them years. My guess would be the 08 time frame and maybe again around 11, so the paint codes don't carry through. The colors look very similar, but the paint codes are different. I'm not sure if that's because the colors are actually different, or if Ford just wanted to change something.
I googled my 2010 ud ebony black and learned there are for ford codes called everything from mustang black, black, ebony black, absolute black, codes ua ub ud yc which are all the exact same color.
not sure why would change the name and the code for a color, but they do.
why don’t you just drive the truck next to the bed and see if it matches.
or get the code for both years and see if touch up paint uses the same codes .
So, I followed speakerfritz's advice and started looking up touch-up paint codes from different manufacturers. As he mentioned, the blacks across the years all shared the same product code from a certain manufacturer, regardless of Fords different paint codes. However the colors of my truck(T5 AQ), did not match any 11 MY colors. I had thought that might be the case after looking into it more.
I would like to drive my pickup next to the box in question, but it is 200 miles away.
any my final words why putting the 2011-2017 kit on a pre 2011 would not work.
drilling holes and welding nut plates are no problem.
