question?
Old Mar 20, 2018 | 11:19 AM
Megathomas's Avatar
Megathomas
Exclamation question?
my 95' Ford F-350 with a 351W won't crank up with out starting fluid, once its cranks it doesn't need the fluid to start?
Old Mar 20, 2018 | 11:22 AM
subford's Avatar
subford
You want to rephrase that.
Old Mar 20, 2018 | 11:30 AM
Megathomas's Avatar
Megathomas
what do you mean
Old Mar 20, 2018 | 12:07 PM
mrollings53's Avatar
mrollings53
Because that is a statement, not a question.
Cranking is entirely electrical. Starting fluid does nothing to crank an engine over. Starting fluid helps start the motor by adding fuel during cranking.
Check for codes, and post any you get including pass codes. If it starts with starting fluid then you are likely looking at a fuel delivery problem. What is the fuel pressure; key on engine off and running?
Ken N Tx
3.8 & 4.2L V6
Jan 7, 2016 04:33 AM
bob.p
Aug 12, 2014 09:28 AM
ALL BOY
Aug 17, 2011 01:09 AM
Knox
16
Nov 1, 2009 10:37 AM
dirtman15
Sep 6, 2004 06:18 PM
