Rear 4x4 leaf spring pack thickness??
Old Mar 19, 2018 | 10:29 PM
chetspencer's Avatar
chetspencer
So I'm hunting for a pair of unicorns, and would be greatful if any fellow F100 4x4 owners could confirm that the rear 9 leaf spring pack thickness is 3 inches. I'll probably have to have a set custom made, but I see there's a set available for 2 wheel drive but it has a spring pack thickness of 2 9/16" maybe I could recycle a few of my leafs to get the correct thickness. Thanks
Old Mar 20, 2018 | 03:34 PM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
Looking in the 1957-1963 Chassis Catalog the only half ton 9 leaf spring pack I find listed is B7C 5560-C measuring 2.59” thick. Maybe Bill will have a source that I don’t have, but it looks straight forward from the chart. Stu
Old Mar 20, 2018 | 09:31 PM
chetspencer
Thank you, I have a hunch that is the 2 wheel drive part number. I'm open to suggestions BTW on alternative springs (3/4 ton) for my truck. If anyone has done business with a good Spring manufacturer feel free to share your experience.
Old Mar 27, 2018 | 09:39 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The only 9 leaf spring listed is B7C-5560-C
1957/66 F100 rear springs interchange.
C5TZ-5560-D (replaced B7C-5560-C) .. 9 Leaf Rear Spring Pack-1,650 lbs. load rate / Obsolete
2 1/4" wide // 24" > > eye bolt < < 28" // 2 19/32" thick
1957/66 F100 2WD; 1959/66 F100 4WD
I have a hunch that's a 2WD part number.
It's both 2WD & 4WD! See post #5 for 1957/60 F100 2WD & 1959/60 F100 4WD rear spring applications.
Pic: C5TZ-5560-D replaced B7C-5560-C = Column right, 8th entry from the bottom (click on pic twice to enlarge it).
Old Mar 27, 2018 | 09:54 AM
NumberDummy
Pic: 1957/63 Ford Truck Parts Catalog applications for 1957/60 F100 2WD & F100 4WD Rear Springs.
Notice under F100 4WD that it shows B7C-5560-C being replaced by C5TZ-5560-D
Old Mar 27, 2018 | 11:39 AM
chetspencer
Thank you very much for clearing this up.
My1964ford
23
Mar 9, 2017 07:27 PM
SuperDuty93
Dec 7, 2014 03:47 PM
66with352
Feb 2, 2014 09:23 AM
bigjohn87
Oct 13, 2012 12:33 AM
lasthighboy
Nov 22, 2008 10:51 AM
