2018 F-150 XLT Water Leak
#32
2018 F150 Water Leak Update
I just talked to a dealer who employs a "Water Doctor" to resolve these issues on the F150s.
A "Water Doctor"??? Does that tell you how extensive this problem is???
The "Water Doctor" told me that he repairs 5 - 7 of these F150s every week.
He has crews in WV, TN and KY.
I am attaching a photo of the water in the channel underneath the drivers step plate.
It's about 3" deep.
The carpet wicks this water which is what is causing the carpets to be wet - it is not dripping on the carpet.
Picture of water in channel underneath the drivers step plate. Hard to see but it has filled up the entire channel.
I cannot tell whether it is coming from the front or the back because the channel runs the length of the cab.
Why hasn't Ford issued a service bulletin or a recall on this???
I am not the only one having this problem.
It's about 3" deep.
#34
Try this. The AC drain on my 2010 plugged up and was filling the passenger side floor with water. The tech at the dealer said the only way he could fix it was to pull the dash because he couldn't even see the drain pipe because it was behind the engine. I said no, I would deal with it. On my way home I got up to 75 with the windows open and the AC on high blower. I closed the windows. It took a week for my ears to unstop but it blew whatever was in the drain out.
#35
2018 F250 with no sunroof and wet carpet on drivers floorboard. The dealership has done a water test on the windshield with no water showing up. Going to test the third brake light, rear glass and door seals. Any updates on sources/solutions for this problem on other vehicles with this issue?
#36
2017 F150 water is spilling from door track under trim onto driver side floor board. Noticed it a week ago after heavy rains but assumed the AC. No rain for a few days and no water even with AC blasted. Rained last night and sure enough water is back. Would like to just fix this myself rather than dealing with a dealer who just wants to get me out of their hair. Please post fixes for driver side water if found.
No sunroof or back sliding glass on this model.
#37
Try this before you shut your truck off turn off all of the Vents and Recirculation by hitting the off button all of the lights should be off on the Panel for
the HVAC control even shut off the fan,I had a Vent or Blend door that allowed water in from under the Dash and Soak the drivers side Floor,and check
under the Dash for water marks.
#38
Water leak 2018 F-150 King Ranch
I'm having the same water leak issue on my 2018 King Ranch. Doesn't matter if it rains outside or I go through a car wash, the door(s) on the drivers side are not only leaking, they are holding water and not draining, I can hear the water sloshing around, need to take to my dealer to see if they can figure out the issue.
#39
#40
Leaks
#41
You know Guys I wonder if its coming in between the door gasket and the Body,When I close the doors in my Supercab they don't feel like they're closed I'm constantly Reclosing my doors
,I saw you had your door sill full of water and it wet the carpets.Take it to a Auto car wash and you'll see where its coming in
#42
It's about 3" deep.
It's about 3" deep.
They said they found 3 leaks and have another one they need to pull the dash for. I am driving a much nicer "rental" they supplied, but I want mine back. I am scared to use this one because if it gets dinged or scratched or anything it will cost me my deductible.
I love my truck but I am going to ask for the lemon law deal in 10 days.
#44
Just purchased 2018 F-150 last Friday, took it back yesterday because of a water issue like these here. They called me today and let me know that they found the issue, it was a cab vent on the back of the cab between the truck cab and bed, it was not sealing properly and was letting water in. They are replacing both driver and passenger side vents as well as the carpet so there will not be a mold issue.
Not sure if this will help you with your problems or not but its worth looking in to....assuming my ford service guys know what they are talking about!
#45
Well just joined as I had to drop off our 2017 King Ranch at dealer. Water leaking from passenger side post, near Windshield. Unsure where leak is originating. But the mats, carpet are soaked and sounds like an ocean sloshing when you come to a stop under passenger seat area. Just sic about it. Will see what the remedy is. But as an electrical engineer... water and electronics do not play well together. :{
