75 h 390 ignition issues
Well, that's not quite the same probably, as the failures are the ICM's and not the distributors specifically. So maybe you're right.
That said though, I've never had any trouble with Ignitors over the years.
Where is your Red wire getting it's power from elkarcher? What about the coil?
The Ignitors like the full 12v rather than running off of the original resistor wire. The coil might, or might not like 12v though, depending on exactly which part number you bought.
What about the gap between the magnetic pickup and the reluctor/rotor/thingy? Should be .030" if I remember. The Ignitor comes with a feeler gauge to set the gap. If it's slipped over time it can give you erratic running.
It's true what 1976 says, that your Pertronix device might be at fault. But there are other things to check as well.
Good luck.
Paul
We've been lucky so far, and I don't remember ever hearing of a Centech-supplied ignition switch going bad prematurely on the Broncos. But they still can...
Did you use a ballast resistor, or just wire the ignition straight to full voltage?
Ignitor Red wire connected to the coil's positive post? Or has it's own source?
Are you still running the radio noise suppressors? One on the coil positive? If so, if one starts to fail it can short to ground and cause ignition stoppage.
Paul
Although I have not heard of any directly, we sell a lot of Bronco ignition switches too, so very likely at least some of them have come back over the years. Recently a lot of stuff we get from the auto parts suppliers is just crap. Ford starter relays being probably the number one fail that I read about on the forums.
The original stuff must've been crap too. A couple of years ago a guy drove up from Monterey to one of our build-parties and on his way out of the parking lot, his switch fell into pieces on the tunnel. What crap for only lasting 45 years!
Good luck with yours. Actually a faulty ignition switch would not be a bad thing. At least it's quick to track down, and relatively easy to replace.
Paul
Paul
tch and it's good. I did notice that i have 12v at the coil when the ign switch is on not running, on both the POS and neg side of the coil. I swapped out the coil with on old one I thought was burned up and the truck fired right up. Still get the hesitation so I'm lost. I did install the fitech injection system on it and then this **** starts. It's installed just like the directions say. So I'm at a loss. Any help would be greatly appreciated. Thanks Tim
I'm sorry, but that would have been exceedingly helpful to know right up front.
Ok, sorry Tim, but yes I am throwing you under the bus for them moment to vent a little frustration. Why didn't you mention this little tidbit before now? What makes you think it can only be ignition related when you'd just installed a completely new fuel system, on a rebuilt engine and new wiring system, that probably also needs some fine-tuning out of the box?
You said you followed the instructions? Did you do an extensive setup procedure? Lots of people install these "per the instructions" and can't get them to get out of their own way at first. Not until some extensive pre-programming and mechanical setups are performed.
Are you by any chance running the Fuel Command Center in the engine compartment? Or are you running an inline or in-tank pump setup? Running a return line?
What about the intake manifold? Is it a dual plane or open plenum single plane? Some of these don't meter their fuel very well with a fully divided plenum. A small open-plenum spacer, or better yet a bit of grinding on the divider to open thing sup, can really help modern TBI systems.
In your first post (I think it was first) you mentioned that when you jumpered the starter relay it fires right up. That certainly does sound like an ignition switch on the surface, but not once you add a TBI and computer to the mix,
Ok, so that's good news. What did you test?
You found power going in, and power going out at all the right places and the right times then? That's a very good sign.
Where are all the FiTech wires connected? Sounds off the top that it does sound like you have the proper connections, but what about extra grounds?
Things that can cause a hesitation are improper ignition timing AND improper fuel mixture (usually too lean) from insufficient accelerator pump function sometimes. IN fact, this is very common on EFI swaps. You may need to do more tuning.
Because you have an Ignitor, I'm assuming you are not trying to get the FiTech to control the timing, correct?
What about your PCV valve? How is it connected? And what valve are you using? Is it the one specified for your engine?
And where is your vacuum advance connected to the TBI? Ported, or "timed" vacuum? Or full vacuum? Or do you even have vacuum advance?
What is your timing set to?
What kind of fuel setup? Full return line? In-tank pump, or FCC, or inline, or low-high-accumulator setup?
What about a pic of the under-hood stuff? Maybe we can see something out of whack. Probably not, but at least we get to see more pics of trucks and engines and wiring!
There's a whole crap-ton more stuff to talk about now. Rebuilt engine and new wiring from the ground up and new fuel system, including EFI computer and it can be many things causing a hesitation.
But hey, at least it runs after all that! Some can hardly get theirs to fire up after a full rebuild. Much less an EFI swap.
And again, sorry for the attitude. But hearing all that stuff and realizing that it might not have as much to do with ignitions as with fuel came as quite a shock.
If you had said that somewhere else and I missed it, sorry about that too. But I didn't see it.
Good luck.
Paul
Not to mention all the knowledgeable pronouncements of sure-fire solutions...
Gotta' admit... I was kind of looking forward to it.
Paul
