Spot Lamps. Just discovered these
You can make a wiring modification to the spot lamps so they stay on at all speeds. There is mention of it on this forum as well as the F-150 forum. The problem is that having these on can be blinding to other drivers and is illegal. They do throw off useful light and I might make the mod just to have them stay on at higher speeds while plowing, etc...or maybe just operate the passenger side light on the highway.
These lights were intended by Ford 100% to be used as a stationary work lamp, specifically to set up a campsite, etc.
That being said, it's not going to be exceptionally likely.
I'm thinking that it may be possible to keep the side spot lamps just as factory (manual on below 6mph, auto off at 6mph) AND add a wire to two of the upfitter switches that would override the speed and just turn them on (using two upfitter switches; one for each side; or one upfitter switch that would turn on both).
That way I could use them without fear of leaving them on unintentionally while driving, but could "force" them on if needed.
I'll have to give it some thought, but I think this may be pretty easy.
Jim
Jim
I need to figure a way out to mount some side lights. I liked the ones shown above between the running board and the bodywork, but my truck has the automatic running boards so the boards would be in the way unless I mounted them below the boards when they're in the retracted position. It would be handy to have good side lighting when driving around in an rv park in a national forest at night.
Question for anyone that mounted IN the rear bumper - how did you cut the hole in the rear bumper.
I have a 17 Platinum with painted bumper. I like the look of flush mounted rear mounted lights and am thinking of adding some.
I may attach the lights under the rear bumper, but think the in bumper mount looks cleaner - plus the light would be better protected.
Thanks - Jim
Thanks - Jim
Jim
Jim
Hope this helps
Jim
Jim
Jim,
If I can't get the spots to come on with a blinker the upfitter option would definitely be a great second choice. Please keep us informed on your progress. Great idea.
Thanks - Jim
Thanks - Jim
The existing LED light is soldered into a circuit board and is not a replaceable bulb. Maybe the aftermarket will eventually come up with a complete replacement. I'd like the lights to be brighter, but they are better than nothing. Ford still has to follow DMVSS rules in order to be able to sell the trucks...
