F1 transmission interchange ????????
on
So I got a call today from a friend who is helping another friend finish the build on an F1. I went to look at it tonight and from what I can tell its an 48-52 F1 chassis with a 51-52 front clip and a 48-50 cab. A rebuilt 239 flathead is installed and they are having transmission problems. When he went to install the 4 speed spur/ crash box the trans mount is WAY different then what the trans cross member looks like it needs. Doing some quick googooing it looks to me like the truck was "born" with a three speed trans. The rear mount type that looks like "wings" coming off the side. The crashbox 4 sp has the bottom mount and of course has the tail of the trans way to high. So the question is can a 4 sp go in this truck with some changes or a different mount? different cross member or do they need to source a 3 speed. I'm not very well versed in F1s so thanks in advance for any help and comments. It seems odd to me that Ford would have used different cross members for different transmissions but maybe they did?
Someone will correct me soon as in say this but can't you swap the rear mount of the 4 speed to the rear mount off a 4 speed that came in an f1?
sounds like 4 speed he has is from an f2 f3 truck with the rear mount to match the f2 3 crossmember?
Maybe I'm just confused again, need to compare them side by side I guess? I think ive got a f1 rear mount off what I though was a 4 speed. (It was in an f1) Its all wrapped up at the moment but will have to pull it out for a look.
kens65fb
09-02-2016 08:34 AM
farmall_7
04-25-2016 05:59 PM
Poes
16
11-25-2014 06:54 AM
rich51fordtruck
05-22-2006 05:34 PM
