flare side rear bumper
Old 03-16-2018, 08:36 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by monkey-1
I doubt that is factory but Number Dummy will likely clarify.
I looked at that bumper yesterday, then looked thru the parts catalog. It's aftermarket, not genuine Ford.
Ford never offered a step bumper for any year Flareside. See post #9 for the 'channel' bumper that Ford offered for Flaresides.
Old 03-16-2018, 10:38 AM
keithbutts's Avatar
keithbutts
keithbutts is offline
Franklin 2 I’ve never been pulled over in that truck. And there’s a few illegal things on that truck and the fact that I’ve past a cop doing 20 over the speed limit and nothing happened.
monkey-1 no my dad has a sign shop also so I’ll probably have him make them. But as of right now the truck has a multi fuel motor, it runs on gas and oil.
numberdummy could that have been a dealer installed option, because doesn’t each dealer have its own option catalog. And sometimes those options aren’t ford options. At lest that’s what dad told me
Old 03-16-2018, 10:59 AM
NumberDummy
Originally Posted by keithbutts
NumberDummy could that have been a dealer installed option?
Possibly.
Doesn’t each dealer have its own option catalog?
Not necessarily, some may, some may not..
And sometimes those options aren’t Ford options. At least that’s what dad told me.
It could have been a dealer installed option, but the dealer did not buy it from FoMoCo, since it's an aftermarket bumper.
Anything installed by dealers will not be listed on build sheets, because they would have been installed after the trucks drove off the assembly line.
Old 03-16-2018, 11:02 AM
reamer's Avatar
reamer
reamer is offline
F100 Trucker made the stickers?
Old 03-16-2018, 02:32 PM
Dyn Blin's Avatar
Dyn Blin
Dyn Blin is offline
Originally Posted by reamer
Shall I start making some license late brackets???????
You bet! I'd buy.
Are you considering the OE Styleside bracket with the corner cut to make it fit, or the original Flareside bracket?
If the latter, I have a beat up original example I can send you to model.
Old 03-16-2018, 04:17 PM
FuzzFace2's Avatar
FuzzFace2
FuzzFace2 is offline
Received 2,253 Likes on 1,921 Posts
Reamer, I would go for original Flare side plate bracket if you were to make them.
Dave ----
Old 03-16-2018, 04:24 PM
keithbutts's Avatar
keithbutts
If the brackets are just metal why can’t some of you guys make them? I know most of you guys can use a welder I’ve seen your build threads.
Old 03-16-2018, 04:45 PM
Dyn Blin's Avatar
Dyn Blin
Dyn Blin is offline
With the light, getting something close to OE is a challenge, See the pics below
Besides, Ron does some great stuff, it's great to see him artfully put his work together, and I like to pitch a few bucks to support guys whose skill far exceed mine.
Old 03-16-2018, 05:13 PM
keithbutts's Avatar
keithbutts
Well ya I like helping friends out too but a piece of sheet metal with rolled edges and and a cut out for a light.
Old 03-16-2018, 06:05 PM
reamer's Avatar
reamer
reamer is offline
This is what I've done for FTE'ers
3-D Fog Lamp Bezel
Dash patch for rotted Speaker grille
Diamond plate Bed rails
Tailgate protector
'48-'52 F-series cab corner patches
Dual port air inlet
Original style Brush guard
'48 - '52 Front-of-fender patch
'48 - '52 front Fender-to-running board patch
Old 03-16-2018, 06:44 PM
keithbutts's Avatar
keithbutts
Ya I know I’ve seen most of the things you’ve made reamer. And I would like a new dash pad mine is cracked in a few different spots.
Old 03-16-2018, 07:10 PM
monkey-1's Avatar
monkey-1
monkey-1 is offline
Yes! I couldn’t remember his name on here since I met him IRL, not on here. Great guy.
  #28
Old 03-16-2018, 08:44 PM
reamer's Avatar
reamer
reamer is offline
He made mine too!
  #29
Old 03-16-2018, 09:27 PM
keithbutts's Avatar
keithbutts
Does anyone know where I can get a build sheet for a 85 ford decoding?
  #30
Old 03-17-2018, 09:04 AM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,788 Likes on 1,443 Posts
I didn't read through this whole thread, but people were having success at the beginning of it.
https://www.ford-trucks.com/forums/1...ild-sheet.html
Quick Reply: flare side rear bumper
