Drag link taper
Old Mar 13, 2018 | 08:59 PM
64highboy's Avatar
64highboy
Drag link taper
I’m looking for a couple measurements to determine the taper on a stock draglink. I no longer have the oem and I think the custom one I made might be the wrong taper. If any one has a drag link off a 1961-66 f250 4x4 or a 1959-1964 f100 2wd or 4wd kicking around I need a measurement of the very top of the taper and the very bottom of the taper, so I can try and match it up to something on moogs website. Thanks
Old Mar 14, 2018 | 02:24 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Draglink: What are you actually working on?
1958/60 F100/250 2WD (w/o P/S)/4WD; 1961/65 F100 4WD & 1961/66 F250 with 3,000 lbs. capacity (C1TT-3304-M) is the same, but...
1961/66 F250 4WD with 3,500 lbs. capacity (C1TT-3304-AH) & F350 is different.
Old Mar 14, 2018 | 06:23 PM
64highboy's Avatar
64highboy
It’s a 1964 f250 with the 3500lb axle but I’ve swapped in a steering box out of a 78 f250 4x4
Old Mar 14, 2018 | 06:28 PM
64highboy's Avatar
64highboy
I think the easiest option are these https://www.ruffstuffspecialties.com..._Code=TRESTEER
then i can just switch the drag link and tie rods to one ton Chevy. Simple everything is the same
Old Mar 14, 2018 | 08:01 PM
NumberDummy
The original draglink with stud and adjustable end is: C1TT-3304-AH - TYPE 2 .. The "A" length is 14 1/2."
Applications: 1961/66 F250 4WD with 3,500 capacity front axle & 1961/66 F350 with 3,800 lbs. capacity front axle.
Fordyarddog
Dec 30, 2015 08:30 PM
rtcasey
Aug 14, 2011 12:06 PM
RichS2659
May 23, 2011 06:06 AM
e-tek
Dec 14, 2009 08:04 PM
sgettin
Dec 5, 2009 03:08 PM
