Amazon flush mounted Bull rings vs Ford Bull rings
^^^whs. I try to use the bed tie downs as much as possible, but with the motorcycles, I use the bull rings on top so I don't have to run the tie down through the spokes. Just makes life a little easier.
To the op, another bull ring user here, had them in my 13 all the way up to current. Great product.
The 4025 is the four-ring pack. It has two rings that have a slight offset for the front pockets and they come with a label on the rings telling you to mount them to the front pockets. The Bullrings have a small fish in the ring's well and on the top surface they have "Bullring" marking. And yes, they are a great alternative to Box Link when tying down since they are very easy to reach.
This is not correct. You may have ordered them in a set, but the 4025 part number is a pair. Clearly says that on Amazon and Bull Ring's website, and that's how I ordered and received them.
Hmm. I just looked at the order and it shows 4025 as the item number. I ordered one. In the item text it says "two pair" and that's how they were boxed from Bullring...all four in a single box with two having the label for mounting at the front of the bed. To wit; https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
They fit and work great. I'm very happy. No problems with interference with my BAKflip either.
Jim
Just installed all 4 Bull Ring. Ordered #4025's from Amazon as a set of 4. I didn't need the offset ones, my bed cap lines up fine in front.
But, they sent a pair of 4025 regular and a pair of the offset ones, with the packaging stating 'front bed pockets'
No problem, the offset Bull Rings fit fine in a non offset bed rail cap.
Anyone interested in buying the Bull Rings off of Amazon, they have a deal for same $29.95 that give you four straps. I just ordered two pairs....eight straps will be coming my way too.
https://www.amazon.com/gp/product/B0...k_ql_qh_dp_hza
#29
#30
https://accessories.ford.com/catalog.../category/198/
