2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Amazon flush mounted Bull rings vs Ford Bull rings
Old 03-14-2018, 08:13 AM
psdxohio's Avatar
psdxohio
psdxohio is offline
Ok.... I have a dumb question. What’s the benefit of using these vs the cleats in the bed to tie things down? Will these withstand a greater load?
Old 03-14-2018, 08:15 AM
System's Avatar
System
System is offline
Prolocutor
Received 1,185 Likes on 569 Posts
Just a different location and will allow easier tying down up high instead of down in the bottom of the bed.
Old 03-14-2018, 08:23 AM
BK39's Avatar
BK39
BK39 is offline
^^^whs. I try to use the bed tie downs as much as possible, but with the motorcycles, I use the bull rings on top so I don't have to run the tie down through the spokes. Just makes life a little easier.
To the op, another bull ring user here, had them in my 13 all the way up to current. Great product.
Old 03-14-2018, 08:39 AM
C12H24's Avatar
C12H24
C12H24 is offline
The 4025 is the four-ring pack. It has two rings that have a slight offset for the front pockets and they come with a label on the rings telling you to mount them to the front pockets. The Bullrings have a small fish in the ring's well and on the top surface they have "Bullring" marking. And yes, they are a great alternative to Box Link when tying down since they are very easy to reach.
Old 03-14-2018, 08:54 AM
BillyE's Avatar
BillyE
BillyE is offline
This is not correct. You may have ordered them in a set, but the 4025 part number is a pair. Clearly says that on Amazon and Bull Ring's website, and that's how I ordered and received them.
Old 03-14-2018, 10:33 AM
C12H24's Avatar
C12H24
C12H24 is offline
Hmm. I just looked at the order and it shows 4025 as the item number. I ordered one. In the item text it says "two pair" and that's how they were boxed from Bullring...all four in a single box with two having the label for mounting at the front of the bed. To wit;
Amazon Amazon
Old 03-14-2018, 11:27 AM
psdxohio's Avatar
psdxohio
psdxohio is offline
Hmm. I just looked at the order and it shows 4025 as the item number. I ordered one. In the item text it says "two pair" and that's how they were boxed from Bullring...all four in a single box with two having the label for mounting at the front of the bed. To wit; https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
you can also buy just one pair of 4025 bull rings here:
https://www.amazon.com/dp/B01LZ4Z1CL/?coliid=IGZQYRT2IA55Z&colid=2DFVR765UP0HK&psc=0&ref_=lv_ov_lig_dp_it https://www.amazon.com/dp/B01LZ4Z1CL/?coliid=IGZQYRT2IA55Z&colid=2DFVR765UP0HK&psc=0&ref_=lv_ov_lig_dp_it
Old 03-14-2018, 04:58 PM
Carnac22's Avatar
Carnac22
Carnac22 is offline
Same for me when I ordered from Amazon - got ones marked for use on the front pockets.
They fit and work great. I'm very happy. No problems with interference with my BAKflip either.
Jim
Old 03-18-2018, 03:10 PM
momach's Avatar
momach
momach is offline
Just installed all 4 Bull Ring. Ordered #4025's from Amazon as a set of 4. I didn't need the offset ones, my bed cap lines up fine in front.
But, they sent a pair of 4025 regular and a pair of the offset ones, with the packaging stating 'front bed pockets'
No problem, the offset Bull Rings fit fine in a non offset bed rail cap.
Old 03-19-2018, 12:42 PM
h20camper's Avatar
h20camper
h20camper is offline
Anyone interested in buying the Bull Rings off of Amazon, they have a deal for same $29.95 that give you four straps. I just ordered two pairs....eight straps will be coming my way too.
Amazon Amazon
Old 03-19-2018, 12:52 PM
Rustofer's Avatar
Rustofer
Rustofer is offline
https://www.amazon.com/gp/product/B0...k_ql_qh_dp_hza
Youch! That same item is $108.25 on their Canada website. But free shipping!
Old 03-19-2018, 12:53 PM
951 DAN's Avatar
951 DAN
951 DAN is offline
Dude, thats a hell of a deal! I just bought 3 pairs two weeks ago so I missed out on 12 free straps, oh well. The 4025's are better built than the previous rings in that you can pull up on the ring and it will lock in the up position.
  #28
Old 03-19-2018, 01:02 PM
Alaskan_Warbird's Avatar
Alaskan_Warbird
Alaskan_Warbird is offline
Any of you guys overly concerned about using these bull rings with the aluminum beds?
  #29
Old 03-19-2018, 01:19 PM
Alaskan_Warbird
And thanks for the heads-up. I just ordered 3 pairs. Still wondering if any of you are concerned about using these with the aluminum beds, tho.
  #30
Old 03-19-2018, 01:52 PM
h20camper's Avatar
h20camper
For what it's worth, Ford supports them as an OEM accessory.
https://accessories.ford.com/catalog.../category/198/
Quick Reply: Amazon flush mounted Bull rings vs Ford Bull rings
