Noisy WDH
Old Mar 13, 2018 | 09:59 AM
jayro88's Avatar
jayro88
Noisy WDH
Hello,
I have recently purchased a used travel trailer that came with a WDH and Anti-sway setup. It works well and I am going through the process of getting everything adjusted for my van. On thing that I have noticed is that it is very loud in regards to making popping and creaking noises whenever I am turning etc. I thought I remembered reading a while back that properly lubricating the hitch can help reduce this. Is this correct? If so, where would I lube it and what kind of lube is recommended?
Unfortunately I don't have a picture of my specific hitch but it looks like the picture below.....complete with friction anti-sway bar.
Old Mar 13, 2018 | 01:34 PM
Terryd91's Avatar
Terryd91
Some of your favorit grease on the bars where they go into the head will help a lot. You can try try lube like graphite too, might not be as messy. My hitch has grease zerks on both sides that make it a breeze.
Old Mar 13, 2018 | 03:29 PM
wrvond's Avatar
wrvond
About all you can do is lubricate all the pivot points. The ***** the friction bar mount on as well as the hitch ball and the holes the torsion bars fit into. You don't want to get any grease on the friction pad. That's about it.
Old Mar 13, 2018 | 03:40 PM
TCNashville's Avatar
TCNashville
Yep I have the same hitch and I lube everywhere wrvond stated. Quieted down considerably but there always gonna make some noise. Also don't forget to remove the sway control before backing into your site.
Old Mar 13, 2018 | 08:21 PM
jayro88's Avatar
jayro88
Thanks. Looking at the pic again mine is slightly different. The bars aren’t attached to the hitch in a sleeve like in the pic. They have a **** at the top and bottom that fit into divots in the hitch.
Old Mar 13, 2018 | 10:14 PM
Terryd91's Avatar
Terryd91
You have trinuion bars, same idea, lube the pocket the nubs sit in.
Old Mar 14, 2018 | 08:24 AM
wrvond's Avatar
wrvond
ten characters
Old Mar 14, 2018 | 08:25 AM
jayro88's Avatar
jayro88
Is there any specific type of lube that is recommended? Using a grease/oil of some kind could prove messy whenever I have to hook or unhook. I usually use a Dry Lube spray in these situations. Has anyone used this in this application with success?
Old Mar 14, 2018 | 08:43 AM
Terryd91's Avatar
Terryd91
I used grease because my hitch has zerks on it so it's really easy and quick. Dry lube should work too depending on what kind it is, may not be any less messy though. I just carry a few plastic bags that i put over the ends of the bars as soon as they come off. That helps keep all the junk off of them too while we camp. I used to put on on the ball too but i would always forget about it and end up losing it somewhere.
Old Mar 14, 2018 | 08:41 PM
HRTKD's Avatar
HRTKD
My Blue Ox WDH had zerks also. I used whatever grease was in the grease gun. It didn't seem to care. It was fairly quiet. The trailer suspension on the other hand made up for it.
My new Andersen WDH has no zerks and it's as quiet as can be. In fact, they tell you to NOT grease the coupler/ball.
Old Mar 15, 2018 | 07:43 AM
jayro88's Avatar
jayro88
Thanks for the input folks. I will clean things up and lube them to see what I get.
Old Mar 15, 2018 | 08:45 AM
Terryd91's Avatar
Terryd91
It should definitely help, but there will be still some noise, just not enough to sound like you're dragging your camper on its frame LOL.
Old Mar 15, 2018 | 09:16 AM
HRTKD's Avatar
HRTKD
If you turn up the stereo the WDH makes less noise.
Old Mar 15, 2018 | 09:48 AM
wrvond's Avatar
wrvond
Originally Posted by HRTKD
<snip> In fact, they tell you to NOT grease the coupler/ball.
I find this interesting. Sometimes, with a new ball, I've ended up using it without grease the first time or two. Every time I've done that the coupler has ground the chrome off the ball. Have you not noticed this on the Anderson?
Old Mar 15, 2018 | 02:54 PM
HRTKD's Avatar
HRTKD
Not that I've noticed. In theory, the ball turns with the coupler, not the hitch.
