Noisy WDH
Noisy WDH
Hello,
I have recently purchased a used travel trailer that came with a WDH and Anti-sway setup. It works well and I am going through the process of getting everything adjusted for my van. On thing that I have noticed is that it is very loud in regards to making popping and creaking noises whenever I am turning etc. I thought I remembered reading a while back that properly lubricating the hitch can help reduce this. Is this correct? If so, where would I lube it and what kind of lube is recommended?
Unfortunately I don't have a picture of my specific hitch but it looks like the picture below.....complete with friction anti-sway bar.
Yep I have the same hitch and I lube everywhere wrvond stated. Quieted down considerably but there always gonna make some noise. Also don't forget to remove the sway control before backing into your site.
Thanks. Looking at the pic again mine is slightly different. The bars aren’t attached to the hitch in a sleeve like in the pic. They have a **** at the top and bottom that fit into divots in the hitch.
Is there any specific type of lube that is recommended? Using a grease/oil of some kind could prove messy whenever I have to hook or unhook. I usually use a Dry Lube spray in these situations. Has anyone used this in this application with success?
I used grease because my hitch has zerks on it so it's really easy and quick. Dry lube should work too depending on what kind it is, may not be any less messy though. I just carry a few plastic bags that i put over the ends of the bars as soon as they come off. That helps keep all the junk off of them too while we camp. I used to put on on the ball too but i would always forget about it and end up losing it somewhere.
Received 6,718 Likes
on
My Blue Ox WDH had zerks also. I used whatever grease was in the grease gun. It didn't seem to care. It was fairly quiet. The trailer suspension on the other hand made up for it.
My new Andersen WDH has no zerks and it's as quiet as can be. In fact, they tell you to NOT grease the coupler/ball.
on
I find this interesting. Sometimes, with a new ball, I've ended up using it without grease the first time or two. Every time I've done that the coupler has ground the chrome off the ball. Have you not noticed this on the Anderson?
on
Not that I've noticed. In theory, the ball turns with the coupler, not the hitch.
